Master the Equation: Solving tan2x + tan x = 0 | Expert Tips & Tricks
  • Thread starter Thread starter rought
    Tan
To solve the equation tan(2x) + tan(x) = 0, the first step involves recognizing that tan(2x) can be expressed using the identity tan(2x) = 2tan(x)/(1 - tan^2(x)). Factoring out tan(x) simplifies the equation to tan(x)(2/(1 - tan^2(x)) + 1) = 0. This leads to two cases: either tan(x) = 0 or solving the resulting equation for the second term. Visualizing the graph of tan(x) can also provide insights into potential solutions. Utilizing trigonometric identities and substitutions can facilitate finding the solutions effectively.
rought
Solve: tan2x + tan x = 0
I have no idea on how to solve this one =/
Well what do you think a good first step would be?
My first inclination would be to take the graph of tan(x), and look visually for a solution (there are likely more than one, but I'd look for the first with x>0.
Then I'd try to use the definition of tan(x) in terms of right triangles to try to get an intuition for how to solve it. If necessary, I'd look into trig substitutions to help solve it, but you might be able to just do it with triangles.
Give it a go...
if necessary, I'd look into trig substitutions to help solve it, but you might be able to just do it with triangles.
I think that this would be the best way to proceed. There's a very simple trig identity that would let you solve it very quickly ... :wink:
oo would I use the trig identity of: tan(2x) = 2tanx/1-tan^2x ?
how would that factor out though =/ ?
Factor out tan(x).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
