Particle subject to position dependent force
A particle with mass m and total energy E is influenced by a position-dependent force F(x) = ξx^4. To find the velocity v as a function of position x, the work-energy theorem is applied, stating that the net work done equals the change in kinetic energy. The work done by the force as the particle moves from x=0 to x(t) is calculated using the integral of F(x). This integral is set equal to the change in kinetic energy, allowing for the expression of v(x). The final step involves sketching the function v(x) to illustrate the particle's motion.
jimz
A particle with total energy E and mass m is subject to a force F(x)=\xi x^4. Find the velocity v of the particle as a function of the position x, and sketch a phase diagram for the motion.
T=\frac{1}{2}m\dot{x}^2
U=constant
F=m\ddot{x}
x=\sqrt[4]{\xi m \ddot{x}}
Not sure where to go from here, or what the phase diagram axes should be. Do I just take the time derivative of x and that's my velocity?
Use the work-energy theorem.
"The net work done by all the forces acting on a body equals the change in its kinetic energy."
Not seeing it...
Assume one-dimensional motion along x. You need the velocity of the particle as function of the position: v(x). At t=0 let x=0 and the kinetic energy=E. During some time period t, the displacement of the particle is x(t) and the change of KE is:
\Delta E = 1/2 mv(x)^2-E
The particle is subjected to a force of form
F(x) = \xi x^4.
The work done by this force while the particle moves from position x=0 to some x(t) is
W=\int_0^{x(t)}{F(x)dx}=\int_0^{x(t)}{\xi x^4dx}
Calculate the integral, make it equal to the change of KE, express v(x), sketch v(x) as function of x.
