Medical Human Pressure: How Much Air & Water Can We Withstand?
  • Thread starter Thread starter Mentallic
    Physical Pressure
Humans can withstand varying air and water pressures, but breathing becomes difficult at depths beyond a few feet without pressurized air, like that provided by scuba tanks. The lungs can only generate a pressure differential of about 20-30 inches of water column, which limits the depth at which a person can effectively inhale. With pressure-regulated devices, the body can endure significant hydrostatic pressures, but extreme depths pose risks. At certain depths, the pressure can exceed the structural limits of oxygen tanks, raising concerns about the effects on the human body, including the ribcage and internal organs. Ultimately, the first factor leading to death in extreme conditions is likely the inability to breathe due to pressure-induced lung compression or failure of the respiratory system.
Mentallic
Homework Helper
What kind of air or water pressures can a human withstand? Approximately when does it become difficult to breathe and eventually impossible to breathe? After this point, would the person being succumb to these extremes be able to hold air in their lungs? What would be the first factor to cause death?
Biology news on Phys.org
Keep in mind that when diving underwater with a scuba tank, you are breathing pressurized air. You can't breathe surface-pressure air more than a few feet down.
Echoing what berkeman said, your lungs can only pull a \Delta P of about 20-30 inH20. But, if you had a pressure-regulated breathing device (SCUBA, etc), your body can physically withstand quite high and low hydrostatic pressures.
In the movie Abyss, they had to use an embryonic style delivery for oxygen (the synthesized embryonic fluid was 'charged' with a finite amount of oxygen and then the diver had to inhale the fluid into their lungs.)
Of course, it's a movie, but I think the rationale is that the oxygen tanks themselves couldn't withstand the pressure at the depths they were going...
But if that's the case, then is there a depth at which the pressure is so much that we can't expand our lungs to inhale, even with SCUBA equipment? I mean if it will crush a metal cylinder of oxygen, what would it do to the ribcage and/or internal organs?
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) he structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
Popular article referring to the BA.2 variant: Popular article: (many words, little data) https://www.cnn.com/2022/02/17/health/ba-2-covid-severity/index.html Preprint article referring to the BA.2 variant: Preprint article: (At 52 pages, too many words!) https://www.biorxiv.org/content/10.1101/2022.02.14.480335v1.full.pdf [edited 1hr. after posting: Added preprint Abstract] Cheers, Tom
23K
14K
