Charging and discharging of capacitors
An isolated conductor can have charge Q, but it is not the same as being uncharged; isolation means it is not connected to any other system. When an earthed conductor approaches a positively charged capacitor, charge can redistribute, but the total charge remains constant, with equal amounts moving between the two. A capacitor typically consists of two plates with equal and opposite charges, and it cannot have positive charges on both plates simultaneously. Charges can only move between the plates of a capacitor through external connections, such as wires connected to a battery. Thus, the movement of charges is limited to the circuit created by the battery and the capacitor plates.
thereddevils
The questions says an isolated conductor has charge Q ...
is isolated the same as uncharged ? If so , how can it have charge Q ?
Also , if an earthed conductor is brought near a positively charged capacitor , some of the negative charges will move to the +ve charged capacitor and vice versa , so would the charge still remain constant ? Or the amount of charge that leave the capacitor equal the amount that came in ?
Isolated means that the conductor is not connected to anything.
A capacitor usually has two plates, with equal and opposite charges. What do you mean on positively charged capacitor?
Charges can move to one body to an other one if there is some conducting contact between the objects. ehild
ehild
could it be that the positively charged capacitor have positive charges on both plates ? Then when it is brought near to a negatively charged conductor , the charges will move across each other right ? Then will the amount of charges on the capacitor the same now ?
The charges can not jump to one plate of a capacitor onto the other one. ehild
ehild
what if it is connected to a battery ? I thought the battery would pump the charges around .
No, the charges can move only in the wires which connect one pole of the battery to one plate of the capacitor.
ehild
ehild
oh , so the charges can only move to the other side of the plate through the battery ?
Yes.
