Increasing dynamic pressure in a pipe
The project involves using a venturi to inject CO2 into a fish tank, requiring water pressure of 5-10 psi and a head height of 15-20 ft. The user seeks a cost-effective pump with a flow rate of 300-500 gph, as most suitable pumps are either too powerful or expensive. A potential solution discussed is building a reservoir elevated 20 ft, but this limits flow duration and complicates the closed-loop system. Concerns about pump noise and the risk of overpowering the small tank are also raised, along with a suggestion to consider specific water pumps from McMaster Carr. Ultimately, finding a balance between cost, flow rate, and pressure is crucial for the project's success.
petitericeball
I'm starting a project involving a venturi and water, and for the venturi, I need the water pressure to be around 7-10 psi. This means for my water pump, the head height must be around 15-20 ft. Most pumps that fulfill this requirement are either too expensive or are too powerful for my application. I'm looking for a 300-500 gph pump that can give me the 7 psi (most pumps are in the thousands of gph by this point, or are hundreds of dollars). I'm wondering if there is a way to convert flow (gph) into psi (head height) by changing the shape or diameter of the piping. I know if I make the piping smaller, it will reduce pressure (Bernoulli's) but at what point would increasing the diameter of the pipe stop helping me?
What is the reason for this, how long do you need to flow for?
The very cheapest way to get 20 feet of head pressure, is to build a reservoir 20 ft up. This of course limits the amount of time you will get the desired flow rate depending on how big you can make the tank. You can then use a cheap pump to repump this up to the top.
Although to be honest a couple of hundered pounds/dollars for a pump isn't really that much (it's certainly not silly money) and that would be by far the best way to achieve the goal.
Okay, I'll go through what I actually need to do... I am using a venturi (mazzei injector) to pump CO2 into my fish tank for the plants (I know.. nerdy) and am also supplementing macro/micronutrients. For the venturi to work properly, it needs between 5-10 psi of pressure (when the venturi goes through the narrow part, it speeds up, agitates itself, and when I inject the CO2 at this point, the absorption rate goes way up, near 100%. The problem with the water supply 20 ft up, is getting the water up there. This will need to be a closed loop (meaning I'm not going to be filling the reservoir with the faucet and end up draining the water from the fish tank into the drain), so then the pump still needs that 20 ft of head height, and I might as well just connected the pump directly to the injector. Since this is a small project (30 gallons) the 1500gph that I would get with the normal water pumps would totally destroy my tank (fish getting sucked up, plants getting uprooted). If I had something like a 75-125 gallon tank, I would probably go with the $150 pump, but I'm hoping I won't have to.. :)
I was thinking a weak well/sump pump might work, but I'm worried about noise, and that it will be running 24/7, unlike the ones in your home.
Sounds like a swimming pool pump to me. There are also water pumps in McMaster Carr that do exactly what you're asking. Take a look at P/N: 9989K56
http://www.mcmaster.com/#water-pumps/=7k1e8o
(7.5 GPM @ 20 ft head)
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
