How Can I Generate Two 1024 Bit Prime Numbers Using the AKS Primality Test?
Anzas
im making an algorithm in which i need to generate two 1024 bit prime numbers, is there a way of doing this? i read that there are some ways to see how probable it is that a number is prime, can you guys point me in the right direction?
I would do a google search on the keywords prime (or primality) + test (or testing). Looking for a mathworld or wikipedia page on it is probably good.
There is a really good primality testing algorithm, but I don't know its name. I think Rabin's test is a good one, but don't quote me on that. :smile:
Well, if you have giant capacity but only normal speed, you could just look up a database which is sitting on your hard drive ?
I don't think you grasp just how many 1024 bit primes there are!
Can't you just download the PGP source (http://www.pgpi.org/) and see which algorithm it uses to get its prime numbers? I can't remember off the top of my head and am about to run to the beach. Be back later.
- Warren
I didn't really think very much about this and - that's why people don't do this, I guess - that's why I punctuated that line with a question mark instead of a period.
I imagine there would be about 2^1014 primes less than 2^1024 ?
2^1014 is about the right order of magnitude.
You expect the probability a randomly chosen number near 2^1024 is prime is something like 1/1000.
The Rabin-Miller test is usefull, and can tell you a given number is prime with whatever probability you like (the closer you take this probability to 1 the more sure you are it's prime, and also the longer the algorithm takes).
Once your number has passed Rabin-Miller, you can send it into the Elliptic Curve Primality Proving algorithm (ECPP) which can certify that your number is prime (or determine it's composite). This takes longer than a probabilistic test, but if you want guaranteed security, it's the way to go.
You should be able to find many versions of both these algorithms (and many others) online.
i think i found a way to find probable primes using Fermat's Little Theorem...
if i want to check the number "n" for primality
i pick a number "a" such that a < n
and if
a = a^n mod n is true then n might be prime (i need to try sevral "a" values to have higher probability)
fermat's little theorem fails for some numbers (these are called pseudo primes but they hold no interest to whatever u are doing).
One could go with shmoe's suggestion or try AKS primality test (dunno of any software using this one yet so u could be the first :D)
Check this page for a lot more interesting stuffs
http://www.utm.edu/research/primes/prove/index.html
-- AI
well I am trying to implement the rsa encryption algorithm so i think pseudo primes should do as well even though they won't work with some values most chances it will work fine
Anzas, you can download pgp for free.
well pgp is written in c and I am programming in visual basic
porting it would actually be more work then writing it from scratch
several implementations:
http://fatphil.org/maths/AKS/#Implementations
There have been many improvements to the algortihm since AKS first appeared, but I don't think any of them are faster than the best implementations of ECPP for practical purposes.
