Determine the kinetic energy of the electron as it leaves the electron gun
The discussion focuses on calculating the kinetic energy of an electron in an electron microscope's gun, where electrons are accelerated to 8.90% of the speed of light. To find the kinetic energy, the formula k=1/2mv² is used, with the mass of the electron being necessary for calculations. The electric force acting on the electron can be determined through the relationship between energy gain and work done by the electric field. For acceleration, alternative equations that do not require time can be utilized. The conversation emphasizes understanding the principles of physics to solve the problem effectively.
elizabethrae
In an electron microscope, there is an electron gun that contains two charged metallic plates 2.75 cm apart. An electric force accelerates each electron in the beam from rest to 8.90% of the speed of light over this distance. (Ignore the effects of relativity in your calculations.)
(a) Determine the kinetic energy of the electron as it leaves the electron gun. Electrons carry this energy to a phosphorescent viewing screen where the microscope's image is formed, making it glow.
(b) For an electron passing between the plates in the electron gun, determine the magnitude of the constant electric force acting on the electron.
(c) Determine the acceleration of the electron.
(d) Determine the time interval the electron spends between the plates.
So I know you can find kinetic energy with the equation k=1/2mv2 but what would I use for the mass? I assume you would just have to calculate out the velocity from the percentage of the speed of light correct? I have no idea what to do for b) and d). And for c) I assume you would do delta velocity over delta time but what would the time be?
Thank You!
Welcome to Physics Forums.
Since the particles in the problem are electrons, use the mass of an electron.
Yes, correct.
For (b), you could use the fact that the energy gain of an electron equals the work done by the electric field. There is also a formula that relates work done to the force applied to an object.
You don't have to do that, there are other equations that involve acceleration and do not involve time.
