Dark Matter & Its Effects on Regular Matter
Dark matter is theorized to exist throughout the universe, yet its effects on regular matter, including our bodies and the solar system, are minimal due to its sparse distribution. Calculations suggest that the total mass of dark matter within the solar system is approximately 10^19 kg, which is too small to create significant gravitational effects. The gravitational influence of dark matter is diluted because it is spread over a vast volume, making it difficult to detect. Additionally, while dark matter contributes to the dynamics of galaxies, the solar system's density is much higher compared to the surrounding galaxy, resulting in different gravitational behaviors. Consequently, the velocities of planets in our solar system decrease with distance from the Sun, aligning with the expected gravitational effects of visible matter rather than dark matter.
MNyberg1020
If dark matter really does exist everywhere, and is constantly passing through our bodies, why doesn't this extremely dense matter affect regular matter? How are the atoms of our body not pulled by dark matter's gradational field? Also, if dark matter is thought to exist because stars in galaxies are moving too fast to be held in orbit by regular matter alone, why doesn't our solar system demonstrate those same properties if dark matter is everywhere? Why do the velocities of our planets drop the farther they are from the sun? Shouldn't our planets be affected by dark matter too?
Astronomy news on Phys.org
I've done the crude analysis in the past somewhere on this forum, but I don't feel like digging up the post... The point is, if you do the calculation, you find out that the total mass of dark matter within our solar system should be ~10^19kg, roughly uniformly distributed between the sun and the outer edges of the Kuiper belt. Now, 10^19kg is around the mass of a medium sized object in the asteroid belt. So, to begin with, the gravitational perturbation from such an object is tiny, but then considering that it is smeared out over dozens of AU makes the effect much more difficult to detect.
If you were to take the mass of the Sun, planets, etc of the solar system and divide it into the volume of the solar system, the average density you got would be much much greater than if you were to take the mass of all the star systems in a large local section of the galaxy and divide it into the volume of that section. In other words, the Solar system is a dense pocket compared to the local region of the galaxy.
Now consider that the vast majority of visible mass of the galaxy is constrained to a disk and dark matter is spread out in a spherical volume enclosing that disk. So even though there is ~5 times as much dark matter than visible matter in the galaxy, it is not dense, but rather spread out over a much larger volume and very thinly. So as Nabeshin has already said, you would expect to find very little dark matter within the Solar system.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
