How Do You Calculate the Probability of a Heart Attack in a High-Risk Group?
In a high-risk group with a 70% chance of individuals having suffered a heart attack, the probability of at least one out of four selected individuals having a heart attack can be calculated. The correct approach is to first determine the probability that none of the four individuals have had a heart attack, which is 0.3 raised to the power of 4. The final probability of at least one person having a heart attack is then found by subtracting this value from 1. The initial calculation of 2.8 is incorrect, as probabilities cannot exceed 1. The discussion emphasizes the importance of understanding dependent versus independent events in probability calculations.
Calculator14
In a certain high-risk group, the chance of a person having suffered a heart attack is 70%. If four persons are chosen from the group, find the probability that at least one will have had a heart attack.
(work shown below) these would be dependent
(.7)/(4) = 2.8
It might be easier to think of the chance that a specific individual doesn't have a heart attack, so what are the chances that none of the individuals have heart attacks (and you might want to rethink the dependence).
your answer is wrong
i don think it is a dependent event
the probability of a person with heart attack is 0.7
so the probability that among 4 at least 1 has heart attack = 1 - probability that none have
= 1 - (0.3)^{4}
must be correct but verify it
Amateur's answer is correct.
Your attempt doesn't make any sense.
Remember: probability can never be more than 1.
So if you find 2.8, think again.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
