I 4 dis wednesday. A contest I win 2 thou dollars HELP HOW TO MOVE a truck
  • Thread starter Thread starter litmyfirebabe
    Contest Truck
The discussion focuses on a competition requiring participants to move a 25-30 ton truck using only human force and a chain attached to the front. Participants cannot touch the truck itself, modify it, or use external supports like trees or pillars. Suggestions include using a hand-cranked winch with a suitable anchor, such as cinderblocks, to create leverage. Questions arise about the rules regarding touching the truck's tires and the possibility of using levers without direct contact. The urgency is emphasized as the competition deadline has passed.
litmyfirebabe
2 thou dollars! HELP HOW TO MOVE a truck
i need on help on how to move a truck of 25-30 tons by just human force. its a competition and the scores are based on a balance of time, people used (the less the better) and creativity of the system. there are 3 trucks and we have to move each 10 meters. rules are, that you can't touch the truck, only can touch a chain that is attached to the front of it, and u can't destroy the street or change anything in the truck or street. and there is no trees to use as support or amy pilar can be used. only u and ur system. please someone help me find a system
When you say "there is no trees to use as support or amy pilar can be used", can you supply your own anchor as part of your system?
I vote for a hand-cranked winch. But you'll need some sort of anchor like brewnog said (if you have time, you can just use a pile of cinderblocks as a counterweight.
Qs:
Level ground?
*You* can’t touch the truck - including tyres?
Can you use a 2x4 as a lever to wedge the tyres (not actually touching the truck)?
Mind you, Wednesday's been and gone...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
68K
10K
