Light waves, photons; sound waves, phonons; water waves, hydrons ?
jetwaterluffy
Light waves, photons; sound waves, phonons; water waves, "hydrons"?
Light waves are made of photons; sound waves are made of phonons; so are water waves made of "hydrons", and if so, how would they behave, and would it be possible to make a water laser or something similar based on these particles.
They're called "ripplons".
ripplon n. A quantized capillary-tension wave at the surface of a liquid
jetwaterluffy said:
...and would it be possible to make a water laser or something similar...
We used to call them "squirt guns".
:smile:
:smile:
:biggrin:
Yep, that's what I meant.
I actually meant a laser within the medium, not of the medium. The light version of what you described would be a cathode ray, not a laser.
Thanks for the name, Bill. I tried searching "ripplon" and couldn't find anything acessable. Do you have any suggestions of any sites which might give an introdution to them?
jetwaterluffy, Long-wavelength surface waves are driven by gravity, but as the wavelength gets shorter the effect of gravity becomes less important, and the waves are driven instead by surface tension (see "capillary wave" in Wikipedia). Quantized surface waves ("ripplons") are of this sort, and manifest themselves primarily in superfluid He, either on films or on the surface of bulk helium. I can only find this http://arxiv.org/abs/1003.4709" online that talks about the subject, but it's pretty high powered.
Likes Spinnor
Yeah, I was thinking about this earlier when I was reading a quantum gravity book. It said gravitons were hard to model because of turbulence at high amplitudes and wavelengths. I thought, just like water waves. It also said the gravitons would affect themselves because they affect anything with energy. I thought, water waves are like this too, as their wavelength depends on depth, which they themselves affect. They said it was hard to model gravitons that are not made of short wavelengths and amplitudes. Now, from looking at your post, it appears ripplons are like this too. So maybe studying water waves might tell them something about gravity. This, with the idea of making a water laser, is what got me interested in "hydrons" to start with.
Thanks for the explanation and the paper!
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
