Calculating Range of a Cannon at an Angle
The discussion focuses on calculating the range of a cannon firing projectiles at an angle of π/6 radians above the horizontal, with the maximum range defined as L. The range is determined as the horizontal distance traveled by the projectile, calculated using the x-component of the velocity multiplied by the time of flight. To find the time of flight, one must analyze the y-component of the initial velocity and account for gravitational acceleration. The conversation emphasizes the importance of showing work for clarity and encourages further questions regarding angles for maximum range and projectile speed. Understanding these concepts is crucial for solving the problem effectively.
jli10
A cannon fires projectiles on a flat range at fixed speed but with variable angle. The maximum range of the cannon is L. What is the range of the cannon when it fires at an angle \frac{\pi}{6} above the horizontal? Ignore air resistance.
Four kinematic equations.
I honestly don't know where to start. What exactly does the question mean by the range of the cannon? Is that the horizontal distance the projectile goes?
Yes the range will be the horizontal distance. Since projectiles move horizontally at a constant velocity, it is simply calculated by multiplying the x-component of the velocity by the time of flight.
x=v(x)*t
where v(x) means the x-component of the velocity. v(x) = v*cos(theta)
x = the range
The trickier part is calculating the time of flight. This is done by finding the y-component of your initial velocity, then recognizing that the final velocity at landing will be the opposite of this value. Knowing that the projectile will accelerate at -9.8 m/s^2 you can then solve for the time of flight and substitute it back into the first equation.
v(y-final) = v(y-initial) + a*t
v(y-initial) = v*sin(theta)
v(y-final) = -v(y-initial)
Hope that helps.
range is how far away the target is. Given the maximum range is L then they are looking for a percentage of L when the angle is pi/6.
show some work and people will help.
Yes, the "range" is the horizontal distance the projectile travels.
What angle will produce the maximum range? What is the speed of the projectile if the maximum range is L?
