Poisson's equation applied to an integral
  • Thread starter Thread starter Thomas2054
    Applied Integral
The discussion addresses the application of Poisson's equation to a volume integral representation of potential, specifically in the context of voltage. It highlights the use of Green's function to solve the equation, demonstrating that the Green's function for the Laplace operator can be expressed in terms of spherical coordinates. The solution involves integrating over a sphere and applying Gauss's theorem, leading to the standard form of the solution for Poisson's equation. The final expression for the voltage is derived, showing its dependence on the charge density and the distance between points. This mathematical approach provides clarity on manipulating Poisson's equation in the context of volume integrals.
Thomas2054
This is not a homework problem, but a math question of curiosity. At 57 I am way past courses and homework.
If a potential, V, is expressed as a volume integral, how does one apply Poisson's equation to that integral?
If V = k∫V'\frac{ρ}{R}dv' (V on the LHS is voltage and the integral on the RHS is the integral over V', the volume.)
how do I manipulate Poisson's, i.e., \nabla2V = -\frac{ρ}{ε}?
I cannot find enough in my various calculus books to figure this out. A website reference would be fine.
Thanks.
Thomas
It's not such an easy question as it might seem. The most elegant way is to use functional analysis and the theory of distributions. You look for the Green's function of the Laplace operator,
\Delta_x G(\vec{x},\vec{x}')=\delta^{(3)}(\vec{x}-\vec{x}').
First of all it's clear from the symmetries of the problem that
G(\vec{x},\vec{x}')=g(|\vec{x}-\vec{x}'|).
Setting \vec{y}=\vec{x}-\vec{x}' leads to
\Delta_y g(|\vec{y}|)=\delta^{(3)}(\vec{y}).
Now you introduce spherical coordinates for r=|\vec{y}| \neq 0. This leads to
\frac{1}{r} [r g(r)]''=0.
This you can solve by succesive integration
g(r)=\frac{C_1}{r}+C_2,
where C_{1,2} are integration constants. Since we seek for the solution, which vanishes at infinity, we have C_2=0. The constant C_1 has to be found by the defining equation. To that end you integrate the equation
\Delta g(|\vec{y}|)=\delta^{(3)}(\vec{y})
over a sphere around the origin with arbitrary radius. For the right-hand side you get 1, and for the left-hand side you use Gauß's integral theorem
\int_{K} \mathrm{d}^3 \vec{y} \Delta g(|\vec{y}|) = \int_{\partial K} \mathrm{d}^2 \vec{F} \cdot \vec{\nabla} g(|\vec{y}|).
You easily find
\vec{\nabla} g(|\vec{y}|)=-C_1 \frac{\vec{y}}{|\vec{y}|^3},
and the surface integral thus gives
-4 \pi C_1=1 \; \Rightarrow \; C_1=-\frac{1}{4 \pi}.
So we have
G(\vec{x},\vec{x}')=-\frac{1}{4 \pi |\vec{x}-\vec{x}'|^3}.
Thus the standard solution for Poisson's equation is
V(\vec{x})=-\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' G(\vec{x},\vec{x}') \frac{\rho(\vec{x}')}{\epsilon}=\frac{1}{4 \pi \epsilon} \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{|\vec{x}-\vec{x}'|^3}.
I don't know, how to edit postings in this forums, so here is an erratum to my previous one. The end of the posting must read:
So we have
G(\vec{x},\vec{x}')=-\frac{1}{4 \pi |\vec{x}-\vec{x}'|}.
V(\vec{x})=-\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' G(\vec{x},\vec{x}') \frac{\rho(\vec{x}')}{\epsilon}=\frac{1}{4 \pi \epsilon} \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{|\vec{x}-\vec{x}'|}.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
