Calculating Rate of Change for Cones: Homework Help
jsmith613 said:
I have attached a link along with my working
please can someone help me
http://s359.photobucket.com/albums/oo40/jsmith613/?action=view&current=Math.png
Please post the problem and your work here. IMO, it's a pain in the butt to have to open a web page to see the problem and the work, plus I can't insert a comment at the appropriate place where there's an error.
dv/dt = 4 cm3 min-1
tan(60) = r/hr = √3* hV = (1/3) π r2h
dv/dh = (1/3) π r2
dh/dt = (dh/dv) * (dv/dt)= 1/(1/3) π r2 * 4
= 12/(pi r2)
for h = 4
dh/dt = 0.079577
The answer given is 0.0265 cm/min. why?
I don't know how do use latex - see post for a clearer solution if you get lost!
question was:A hollow cone with a semi-vertical angle of 60 degrees is held vertex down with its axis vertical.
Water drips into the cone at 4 cm3/min
Find the rate at which the depth of water is increasing when the water is 4 cm deep
jsmith613 said:
dv/dt = 4 cm3 min-1
tan(60) = r/h
r = √3* h
V = (1/3) π r2h
dv/dh = (1/3) π r2
You're ignoring the relationship between r and h.
Substitute for r in your volume equation. Then you'll have V purely as a function of h.
What you have is not correct, because V is a function of r and h.
= 1/(1/3) π r2 * 4
= 12/(pi r2)
for h = 4
dh/dt = 0.079577
