What can I do to make my wind tunnel testing project more complex?
The discussion centers on enhancing a thesis project focused on wind loading for a conveyor belt and truss system. The student plans to conduct wind tunnel tests on a scale model to measure drag forces but seeks to increase the project's theoretical complexity. Suggestions include incorporating flow visualization techniques, such as mini tufts and smoke wire methods, to analyze turbulence and vortex shedding effects. Additionally, conducting pressure and velocity measurements in the wake of the model could provide insights into drag components. The student is encouraged to explore computational fluid dynamics (CFD) simulations to deepen their understanding of the complex geometry involved.
Vinnende
Hello all,
I'm in my final year of engineering so I'm required to complete a thesis as part of that. My topic is to investigate the wind loading on a typical conveyor belt + truss arrangement, because there's a lot of uncertainty in industry about drag coefficients etc. I've attached a model of the steel structure below (simplified by removing members parallel to flow), but there's also lots of other services and the conveyor belt itself not pictured. It's 18m long.
http://i.minus.com/jsD6rCU01EZXt.png
Anyway, my plan is to construct a scale model ~(1:10) and do a variety of wind tunnel tests in my universities wind tunnel (sahweet!) for different arrangements/alignments/etc, with the major output being drag force (assuming the other forces and moments are negligible). The problem is, my supervisor doesn't think the whole project is theoretically complex enough, and I guess he's right - at the end of the day all I'm doing is measuring drag on a model.
So my question is, how can I make this project more complex? Right now the only real calculations involve some dimensional analysis/similitude (which I'll try to make as elegant and clever as possible). What else can I do/investigate? Essentially I want to show/prove that I've done my research and know the theory behind the results, so I'd love to include some sort of theoretical analysis, but obviously the complicated geometry makes anything I do by hand irrelevant. I was thinking perhaps include flow visualization in some wind tunnel tests and then discuss the boundary layers/flow separation/turbulence onset, but then what's the point? It's not like the dynamic behaviour of the wind will adversely affect its structural integrity.
Essentially I just want to prove I know my stuff, whilst keeping it relevant to the topic. I'd love to do some sort of CFD analysis, but I fear the geometry is far too complex and I also don't know much about CFD . But if performing a simulation over a small section could provide further insight (and not take forever) I'd love to have a crack!
Any help/comments are much appreciated
I think flow viz could be interesting because the dynamic behavior of the air is certainly important. Turbulence and vortex shedding result in unsteady loading on the body. This unsteady loading can excite certain structural modes and cause serious problems. It also generates noise. I would suggest mini tufts, surface oil flow and smoke wire methods for flow viz.
You could try various modifications to reduce the drag like fairings.
You can do pretty interesting things by measuring pressure and velocity components in the wake of a 3D body. For example with measurements from a five hole probe you can decompose the total drag into profile drag and vortex induced drag. But that would take a considerable amount of additional effort.
If you have the equipment you could perform a simple wake survey with an array of pitot probes and perform a control volume momentum analysis. Or you could make boundary layer measurements and calculate the skin friction.
Thanks very much for your reply! Certainly things I can look into :)
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
