Changing the orbit of a satellite, minimum rocket burns.
The discussion revolves around the mechanics of changing a satellite's elliptical orbit around Earth, specifically rotating the major axis by 90 degrees while maintaining the same energy level. It suggests that two rocket burns may be sufficient to achieve this, either by slowing down at the closest approach or speeding up at the farthest point. Participants note that while this method is energy-efficient, other acceleration points can also achieve orbit changes with a single burn. Additionally, the conversation touches on the concept of impulses affecting orbits, distinguishing between those that change energy and those that do not. The consensus confirms that applying force perpendicular to the satellite's velocity does not alter its energy.
Spinnor
Suppose we have a satellite in an elliptical orbit around the Earth with the major axis pointed towards some fixed point in the heavens. What is the minimum number of rocket burns so that the major axis is rotated 90 degrees and the final and initial energy are the same. Is the number 2?
At closest approach to the Earth, slow down, one burn, orbit circular, 90 degrees later speed back up, one more burn or at farthest approach speed up, 90 degrees later slow down, again two burns?
Thanks for any help!
While your way might be the most energy-efficient method: You can accelerate at other points, too, achieving every orbit which intersects the old orbit in one point, with a single, short burn. With a longer time for the acceleration, you can reach non-intersecting orbits, too.
Thank you mfb! I have to think about the above. This problem I think is related to a similar problem, given a 2 dimensional harmonic oscillator that has some "orbit", what impulses acting on the "point mass" change the orbit? Seems like there are 2 classes of change? Impulses that change the energy and orbit and impulses that only change the orbit?
If I always "push" on a satellite perpendicular to its velocity then I don't change the energy, right?
That is just a special case in the whole range of energies which can be reached.
Right
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
