Simple question about measurable characteristic function
sunjin09
Prove that the characteristic function \chi_A: X\rightarrow R, \chi_A(x)=1,x\in A; \chi_A(x)=0, x\notin A, where A is a measurable set of the measurable space (X,\psi), is measurable.
a function f: X->R is measurable if for any usual measurable set M of R, f^{-1}(M) is measurable in (X,\psi)
Obviously f^{-1}([0,1])=X, where the universal set X need not be a measurable set in a general measurable space (X,\psi), which only requires that the (uncountable) union of all measurable sets is X. But the book explicitly asked to prove for a general measurable space. What am I missing here? Thank you.
X=A\cup A^{c}
But A^c need not be measurable in a general measurable space, which is not necessarily a Borel field, only a \sigma-ring whose union is X. Am I completely wrong?
I've heard of sigma fields and sigma algebras before, but never sigma rings... Is that a variation in which measurability is not closed under complements? I would double check that in your book.
Every book I've seen defines a measurable space as a set equipped with a Σ-algebra. What book are you using?
This is the book I use
http://books.google.com/books/about/Some_modern_mathematics_for_physicists_a.html?id=9PXuAAAAMAAJ
The definition of general measurable space in this book
Definition 7.1(3). Let X be a (universal) set and let psi be a sigma-ring on X which has the property that X is a (not necessarily countable) union of sets taken from the collection psi. Then the ordered pair (X, psi) is called a measurable space. The members of psi are referred to as the measurable sets of X.
A example in the book is let X be an uncountable set and psi be all countable subset of X.
This is a wiki page on sigma-ring:
http://en.wikipedia.org/wiki/Sigma-ring
In the last paragraph:
"σ-rings can be used instead of σ-fields in the development of measure and integration theory, if one does not wish to require that the universal set be measurable."
In the same book there is this problem:
Let (X, psi) be a general measurable space. Show that the characteristic function of A\subset X is measurable iff A is measurable. ( Remark: In the text we gave the proof for a Borel space only. )
P.S. I seem to have figured it out. In the book, for a general measurable space, a measurable function f is defined in such a way that the set on which f is 0 is eliminated. Since \chi_A(A^c)=0, A^c need not be measurable. Thank you both!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
