Different definitions of acids/bases
  • Thread starter Thread starter member 392791
    Definitions
The discussion revolves around the distinctions and relationships between Bronsted-Lowry, Arrhenius, and Lewis definitions of acids and bases. A Bronsted acid donates a proton (H+), while a Bronsted base accepts it. In contrast, Lewis acids accept electron pairs, and Lewis bases donate them, which can create confusion regarding their categorization. It is clarified that while all Lewis bases are also Bronsted-Lowry bases, not all Lewis acids are Bronsted acids. The necessity for Lewis theory arises from its broader applicability, particularly in organic and inorganic chemistry, allowing for the analysis of reactions that do not involve proton transfer. This expanded definition increases the number of recognized acid species and enhances understanding of chemical interactions beyond the limitations of Bronsted-Lowry theory. Despite the complexity of these definitions, they are essential for a comprehensive grasp of acid-base chemistry.
member 392791
I am having some difficulty in understanding the reason for the various types of acids/bases, of which i refer to bronsted-lowry, arrehenius, and lewis acids/bases. A bronsted acid donates an H+ and a bronsted base accepts a H+. However, a lewis accept acceps an e- pair and a lewis base donates an e- pair. This seems contradictory, is a lewis acid a bronsted base and lewis base a bronsted acid? What is the purpose of this, why isn't there a single definition of an acid and base.
Chemistry news on Phys.org
Generally speaking, something is an acid if you add it to water and it lowers the pH. Clearly, an arrhenius or bronsted-lowry acid does this - they simply donate a proton.A lewis acid also does the same thing through the reactions;
X + H2O -> X-OH2 -> X-OH + H+
So we see a lewis acid also produces a hydrogen ion.
I am still not clear on how lewis bases/acids work, or why we need them. It seems that bronsted works just fine
Well, if you add a lewis acid to water, the pH goes down. Bronsted Lowry theory does not account for that. So SOMETHING new was needed.
Lewis acid/base theory is also more generally useful as you'll (possibly) find out in organic and inorganic chem.
Woopydalan said:
"This seems contradictory, is a lewis acid a bronsted base and lewis base a bronsted acid?"
Not quite. A Lewis base is also a BL base but Lewis acids don't have to be BL acids. In Lewis theory, we focus on the electron pair. In BL theory, we focus on the hydrogen proton (H+).
In organic chemistry, we generally are trying to find where the electron/s wants to go. What Lewis theory allows us to do is expand our definitions beyond transfer of just H+. So now we can treat reactions that do not involve proton transfer (BL theory) as acid-base reactions with Lewis theory. Thus we have increased the number of acid species available to work with based on the definition provided by Lewis Theory.
I do agree with you on how the definitions can be tedious or seem whimsical at times. It's important not to get slowed down by them though.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
