Introductory rotational dynamics/energy conservation question
A potter's wheel with a radius of 0.49 m and a moment of inertia of 12.1 kg·m² is rotating at 52 rev/min and can be stopped in 6.0 seconds by applying a radial force of 74 N. The discussion revolves around finding the effective coefficient of kinetic friction between the wheel and a wet rag used to stop it. The user attempts to apply energy conservation principles, equating non-conservative work to changes in rotational energy, while also considering radial forces and torque. Key points include the need to identify the tangential force that provides the stopping torque and the relationship between this force and the normal force exerted by the rag. Understanding these dynamics is crucial for accurately calculating the coefficient of friction.
kinslow31
Hey guy's I am kind of struggling with this i would appreciate any help
A potter's wheel having a radius 0.49 m and a moment of inertia of 12.1 kg · m2 is rotating freely at 52 rev/min. The potter can stop the wheel in 6.0 s by pressing a wet rag against the rim and exerting a radially inward force of 74 N. Find the effective coefficient of kinetic friction between the wheel and the wet rag.
kinematics
Wnc = ΔRotational Energy
Ok here so i started this one trying to do an energy conservation 74Δx(or θ) + uknΔx = (1/2)iω^2
To represent the non conservative forces on one side and the change in rotational kinetic energy on the other, Δx being the stopping distance that can be obtained from kinematics
then i figured there might be a radial component instead of a torque
ƩFr = n + 74 = v^2/r*m
so the radial component gives u an n i can sub back in the conservation equation and it points in the same direction, is this anywhere near right or should i be representing the forces over a torque
You can figure out what the stopping torque was using the info given.
You can figure out what kind of *tangential* force would have to act to provide this torque.
The coeff of friction relates this tangential force to the radial force (which is normal to the surface).
What force is exerting the torque on the wheel?
so i guess i would be assuming acceleration is constant get it from α then
(.49)74-.49(Ffric)=Iα
are the radial force and the friction both part of the x dimension? they just get separate equations so
-ukn = ma and n = (v^2)/(r)*m-74
Only the tangential force exerts a torque.
