Is this current phase shifter ?
  • Thread starter Thread starter JJ91
    Current Phase
The discussed circuit is identified as a series tuned circuit, which operates at a resonant frequency where the reactances of the inductor and capacitor cancel each other out, leaving only the resistance to limit current. While this circuit does not primarily function to shift phase, it can selectively choose one frequency from multiple present due to its resonant properties. The voltage across the capacitor and inductor can significantly exceed the input signal at resonance. The circuit typically operates within the frequency range of 100 KHz to 30 MHz, and its selectivity is determined by the resistor value, influencing the circuit's quality factor (Q). Understanding these characteristics is essential for deriving the transfer function for the circuit.
JJ91
I'm not very familiar with all electronics (power engineering student) but this circuit especially qoes on my head for couple of days now:
Haven't seen such topology but would this circuit change the phase of the supply current with respect to the output point ?
My task is to find a transfer function for this circuit thus I would like to get to know what is the exactly the name of this circuit and its task in electronic world ;)
Thanks,
Tom
That is a series tuned circuit.
At a resonant frequency, the reactances of the inductor and capacitor are equal and opposite and they cancel each other out, leaving only the resistance of the resistor to limit the current in this circuit.
At that frequency, the voltage across C (and L) reaches a maximum and may be a lot larger than the input signal.
They are not usually used to shift phase, but they can be used to choose one frequency when there are several frequencies present, because of the effect described in the last paragraph.
They will work at any frequency, but they are typically used in the frequency range 100 KHz to 30 MHz.
...they can be used to choose one frequency when there are several frequencies present,...
And the value of the resistor determines how frequency selective the circuit is.
The measure of a circuits selectivity is the Q of a Circuit (quality factor).
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
