What is the Coefficient of Static Friction in This Physics Problem?
The discussion revolves around calculating the coefficients of static and kinetic friction for a block being pulled at an angle. Initially, the user misapplied the static friction formula by not correctly accounting for the components of the applied force and the normal force. After several attempts, they determined that the static friction coefficient is approximately 0.577 by correctly calculating the x-component of the applied force and adjusting the normal force. For the kinetic friction part, the user struggled to define the net force, ultimately needing to recognize that the difference between the applied force and kinetic friction equals the mass times acceleration. The correct approach involves using the relationship (Fx - Fk) = m*a to find the kinetic friction force.
HHenderson90
A child pulls a string attached to a block of mass m = 1.5 kg at an angle θ = 35.5° with an increasing amount of force. When she pulls with a force F = 7.39 N the block just begins to move. What is the coefficient of static friction between the block and floor?
F_Static=U_static*F_normal
I first simply called the force she pulls with F_Static, and divided it by the Normal Force (M*G)
This was wrong.
I then thought that maybe only the force in the x-direction would be considered the static force, I found that by FCos(theta). I then divided this by the force normal, and again no luck.
I then thought the force applied by the child in the y direction might be subtracted from the force normal? This didn't work either.
What do I do?
Your second and third approaches combined sound right. The force in the y direction should subtract from the normal force and the force in x direction is the force contributing to making the block slide. It would be a good idea to show your work and the numbers you got.
I ended up getting it correct by combing my second and third approach. Found the x-component of the force applied by 7.39Cos(35.50 which was 6.0163N and I called this F_Static. I found the F_N by M*A which was 15*9.81=14.715
Subtracting the y-component of the applied force (7.39sin(35.5)) I got the F_N as 10.4336.
F_Static= U_s*F_N
Dividing F_Static by F_N I got the answer of .577.
There is a second part to the problem that I am having trouble with now.
1. Homework Statement
Once the block starts to move, it accelerates at a rate of 1.13 m/s2. What is the coefficient of kinetic friction between the block and floor? 2. Homework Equations
Fnet=M*A
F_Kinetic=Uk*Fn
3. The Attempt at a Solution
I think my issue here is what constitutes the Fnet.
I found Fnet by multiplying M*A 1.5*1.13=1.695N
I called this the force applied, considering that the x component would be equal to the force of static friction.
Finding the x component- 1.695cos(35.5)=1.38N
I then took the Fn from before, and subtracted the y component from this force
14.715-1.695sin(35.5)=13.73N
I then used the Fk=UkFn
1.38=Uk13.73=.100
This answer is wrong.
F_Static= U_s*F_N
Fnet=M*A
F_Kinetic=Uk*Fn
1.38=Uk13.73=.100
Your applied x and y forces and normal force are exactly the same as in the first problem. What's different is that the horizontal force Fx and the force of friction Fk combine to accelerate the block. So (Fx-Fk)=m*a. Use that to find Fk.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
