Heat transfer with a plate heat exchanger.
The discussion revolves around designing a liquid cooling system for a highly overclocked computer using a plate heat exchanger. The user is considering using mineral or synthetic oil on one side and water or PC coolant on the other, questioning the optimal placement of the heat exchanger in relation to the radiator. There are concerns about the effectiveness of the cooling setup and whether separate circuits are necessary, with suggestions for a water chiller or thermoelectric cooler instead. Theoretical calculations on heat transfer requirements and maximum temperatures are highlighted as crucial for determining fluid choices. Overall, the project aims for innovative cooling solutions, despite potential redundancy in the cooling systems.
uneducatedphd
First off, I can't believe I never decided to search for a forum like this, I love smart people! lol.
Anyways I am working on a Liquid cooling project for a highly overclocked computer system. Originally I wasn't going to use a heat exchanger(Matter of fact, until I stumbled across one on a website, I didn't even know they made them for PC applications). So I made a crude diagram to better explain. I am planning on running one side with mineral oil or synthetic motor oil and the other with water/PC coolant. My question is would I use to oils in the initial heat area (south) or in the secondary (north) side? My first plan was to use Isopropyl Alcohol and water/coolant, but with evaporation and not wanting to seal the system I scrapped that idea. Also would I want the heat exchanger before or after the radiator? Where would it be most effective at removing heat? Any thoughts or comments would be much appreciated thank you.
I find myself asking is that really necessary. Damm cool though. Have you done any calcs to see what the required heat transfer is to cool it to the required temperature? Do you know what the maximum temperature it will heat upto? That'll help with determining the fluids required. Good old thermo tables.
At the moment it's all theoretical, necessary? Maybe. When setting records, even the littlest bit helps. Not saying that I'm going for records, but I am doing something that as far as I can tell has never been done. Though it looks like there will be some redundant cooling going on, won't know until I try. "Trial and Error" way of the scientist right? Though this is just a rough diagram, it doesn't show the whole project. All of this and more will be in a cabinet directly cooled with a 6,000 btu air conditioner, a few copper coils for extra cooling, though its not known for its insulating properties the cabinet is going to be made of Acrylic. Only thing that will be in the PC case will be the water blocks and hoses. I want the unit to be stand alone as possible. Should look pretty cool when all said and done.
Can I ask the purpose of the two separate ciruits? Why not just make it one circuit?
I would think you'd be better off with a water chiller (thermoelectric cooler) for the liquid and/or a TEC on the CPU itself. Why are you doubling up on the liquid cooling circuits? If you're worried about the cooling capacity of your "south" radiator, you should get a bigger one, and put big fans on it.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
