What Is the Torque When the Line of Force Intersects the Center of Rotation?
When the line of force intersects the center of rotation, the torque is zero because the perpendicular distance from the pivot point to the line of force is zero. The formula for torque, T = F*r*sin(θ), indicates that if θ is zero, the torque will also be zero. To find torque when force is applied at a distance from the center, one must determine the perpendicular distance between the force line and the pivot point. If the force is applied elsewhere, calculating torques from each component can yield the same result. Understanding these principles clarifies how to approach torque calculations in various scenarios.
medo_andnino
what is the torque if you know the the line of force intersects the center of the rotation ?
I think the torque will be T= ( f*sin (45) )*d
But I'm not sure will there be a torque or not ...the intersection of virtual line of force with the center of rotation is confusing me !
About what point are you trying to find the torque?
about the center of the rod
In that case, what would the distance be in your formula for torque?
Torque is the ability of a force to rotate an object around a point.
T = F*r
The distance r is the perpendicular distance between the pivot point and the line of the force that works in on the point (virtual line).
So what is the perpendicular distance between the virtual line of force and the pivot point?
What now ??
medo_andnino said:
What now ??
Where is the force being applied? I assume that the point indicated, which is apart from the center. (1 m to the left and 1 m up from the center.)
The easy way is to just extend the line of the force and see that it intersects the axis of rotation. That should immediately tell you what the torque is, without the need for any calculation.
But if you want to calculate torques from each component separately, that's fine also. You'll get the same answer.
One thing to realize when calculating the torque using F*r*sinθ, is that θ is the angle between the force vector (\vec{F}) and the position vector (\vec{r}).
So you mean that the torque is going to be zero, right !
right...
T= ( f*sin (0) )*r
okay ... one more question to be fully understood the topic ...assume that this left stick is under a pressure (the whole stick) ... Now How can I calculate the torque
