What's the Formula for Calculating the Density of a Gas Mixture?
The density of a gas mixture is calculated using the formula ρ=(m1+m2)/(V1+V2), where m1 and m2 are the masses and V1 and V2 are the volumes of the individual gases. It is crucial to know the ratio of the components in terms of volume, mass, or molar fractions. For ideal gases, while volumes are not additive, the pressures and densities at partial pressures can be combined. The ideal gas law can be applied to derive specific results based on the conditions of pressure and temperature. Understanding these principles allows for accurate calculations of gas mixture densities.
alexmath
what's the formula for the density of a gas mixture? Thank you!
ρ1=m1/v1
ρ2=m2/v2
but the gas mixture isn't ρ1+ρ2.
The density of the mixture is ρ=(m1+m2)/(V1+V2).
From this basic definition you can find various expression, as a function of the given quantities. You need to know the ratio between the two components (in volume , mass, molar fractions etc).
For example, if the volume fractions are given,
V1=c (V1+V2)=c V
V2=(1-c) V
Then
ρ=(ρ1 V1+ρ2 V1)/(V1+V2)=[ρ1 c V+ρ2 (1-c) V]/V=ρ1 c + ρ2 (1-c)
heeey, but volume is not additive. Should i assume it is?
Oh, you specified that you are interested in gases.
The example does not apply then but the general formula does.
Combined with the ideal gas law, should give you the result for any specific case.
In this case you have to decide in what conditions (pressure, temperature) do you take the densities of the components .
If we take the densities of the components at their partial pressures then you we can write
ρ=ρ1+ρ2 where ρ1=m1/V and ρ2=m2/V where V is the total volume of the mixture.
Is this what you need?
ohhhh... if the gases are ideal, volumes are additive then, right?
No, I did not say that. I agreed that my example with additive volumes does not apply for gases. Sorry for not being clear enough.
If you have two gases in a container, each one occupies the volume of the container. They have the same volume and this is equal to the volume of the mixture too. Their pressures are additive (see partial pressures). And the densities, defined at the component's partial pressure, are additive too.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
