PeterDonis
Mentor
- 49,023
- 25,106
Tomahoc said:No I mean 30 seconds in the missile frame.
That's not possible with any of the numbers you've given; a curve going from t = 30 seconds on the Earth's worldline to t' = 30 seconds on the missile's worldline would be timelike, not spacelike. In fact it will be timelike for a missile traveling at any speed fairly close to that of light (off the top of my head I think all that's required is a gamma factor of 2, which requires a missile speed of 0.866c).
Tomahoc said:Because if it reaches the missile at say 1 sec or 25 seconds (let's say it travels continuous and no target), it can produce a scenario where Earth can receive it before sending out.
Not if the tachyon always travels at the same speed in the ether frame. It's easy to show this: just work the problem in the ether frame. There are two possible cases in that frame: Earth and missile both moving in the same direction, and Earth and missile moving in opposite directions. It's straightforward to show for each case that if the tachyon travels at a fixed speed w relative to the ether frame, the Earth can't receive it before it sends it. And since both events occur on the Earth's worldline, their time ordering is invariant; if the signal is received after it's sent in the ether frame, it's received after it's sent in any frame. Work it out.
Tomahoc said:Now does it mean 30 seconds on Earth and 30 seconds on the missile are simultaneous to the aether frame?
They can't possibly be if the missile is traveling at any significant fraction of the speed of light, because the two events will be timelike separated, not spacelike separated. Only spacelike separated events can be simultaneous in any frame.
Tomahoc said:How do you make the aether frame simultaneous to it when they are in relative motion. This is what I was trying to understand.
I think you're going at it the wrong way around. Try what I suggested above: work the problem in the ether frame, treating the tachyon speed w as an unknown, but fixed in that frame. Work it out and you will find that the tachyon signal can't be received on Earth before it is sent for *any* tachyon speed w greater than 1, including speed w = infinity (i.e., the tachyon travels instantaneously in the ether frame).
