Inflate aluminium tube to increase it’s strength?
Pressurizing a thin-walled aluminum tube can enhance its axial compression strength but may increase hoop stresses to dangerous levels, risking rupture. Structural integrity depends on the loading conditions and the balance between axial and hoop stresses. Increasing the wall thickness is recommended for better strength, even if it adds weight. Alternative design strategies include using multiple thin tubes, pre-stressing materials, and innovative shapes to reduce weight while maintaining strength. Overall, careful consideration of material properties and stress analysis is crucial for safe design in human-powered helicopters.
swerdna
I’m designing and hope to build a human powered helicopter (HPH) and am wondering if pressurising a thin walled aluminium tube by filling it with compressed air would strengthen it’s structural properties.
Hope this is the right place to post this.
Good luck with the HPH. Here's a place to start when considering pressure.
e.g. consider the tension on the tubing's wall.
Thanks.
Also, it will depend on the loading on the beam. Pressurizing the thin walled tube induces axial and hoop stresses. Thus you increase it's compression strength in the axial direction, but be very careful that the hoop stresses are not increased so much that you exceed the yield strength causing rupture.
From a stress analysis and fracture mechanics perspective, I would be much more inclined to increase the thickness of the tube walls, even if it increases the weight. Ideally, you can fit several thin tubes inside each other, in order to prevent brittle fracture (which would be veeery bad for you application)
Thanks. I agree that pressurising aluminium tubes probably isn’t the best method. I’m working on other methods that include pre-stressing styrene foam, cable-staying and creating an inverted conical shape with the wing spars and tying them together with multiple lines like a spider‘s web. Overall I’m trying to reduce the weight of the wing spars I use.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
