Friction force in rotational motion
For an object rolling without slipping down an incline, the static frictional force must remain less than or equal to its maximum value, μsFn, to prevent slipping. If the frictional force exceeds this limit, the object will begin to slip, transitioning to kinetic friction. Static friction is present in rolling motion because the point of contact remains at rest relative to the surface, opposing any relative motion. When slipping occurs, the frictional force becomes kinetic due to the relative speed between the contact point and the ground. The fundamental principle is that static friction cannot exceed its maximum threshold, ensuring stable dynamics in rotational motion.
daivinhtran
My textbook says, "for an object rolling without slipping down an incline, the frictional force fs is less than or equal to its maximum value. fs < μsFn
Why is that? What happen it's greater than??
When do we have static friction in rotational motion? (for rolling object)
Then in an example problem about rolling with slipping, it says "there is slipping so the friction is kinetic (not static).? Same question. ==> Why?
For the first question,
friction as in all conditions has a limit.(well u know it). If it weren't that way the world wouldn't function into dynamics(only rotation). down a plane, friction has limit μ*mg*cosθ.if it weren't the way it were, there wouldn't be any slipping. For the moment it might look like it's good. But think like everything stuck to everything.
For second Q,
As you can see that the point of contact in rolling without slipping is at rest.friction acts against the relative motion b/w contact points. That's the work of friction (static).
If you wan't to cause a change in the velocity profile, you have to go against static friction.
For visualization , think a rotating object with spurs (gears) on a profiled (as in the gear) plane.
If it were rolling without slipping, the gear tooth will exactly match into the profiled plane. So there isn't any relative motion b/w the object's point of contact and the plane. If you like to alter the motion you would have to move uphill (That is the static friction in microscopic scale)
causing a relative speed at that instant. If it gains velocity (with slipping) it has inertia . So it turns to dynamic friction. So ,all matters is the relative speed b/w point of contact and the ground (not the body's velocity with the ground)
For second Q,
So what happen if fs > μsFn?
It can not happen. The static friction can not be grater than μsFn.
When you pull an object, resting on the ground, with force F, and F<μsFn the object stays in rest. If the object can roll, it will roll.
If you pull an object with force F>μsFn it will slip.
ehild
what does fs in ur statement mean? frictional force or applied force
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
