Bandwidth at resoance and peak dB level
The discussion focuses on analyzing the bandwidth at resonance in a series RLC circuit when component values are doubled. The user has simulated the circuit and observed a gain peak at -20.82 dB, seeking clarification on how to calculate this value. The voltage across the resistor at resonance is measured at 6.428V, with a total measured voltage of 7.07V due to RMS readings. The calculations involve using impedance equations and finding the peak value by analyzing the derivative of the output voltage with respect to frequency. The breakdown of equations has clarified the process for the user, leading to a calculated peak value of approximately -20.83 dBV.
djstar
Hi,
I'm investigating what happens to bandwidth at resonance of a series RLC circuit when each component is doubled.
i have simulated the circuits and created a bode plot. You can see from the photos that at resonance the gain peaks at -20.82 dB. I would like to know how to calculate this value.
i have an input voltage of 10Vp and the voltage at resonance across the resistor is 6.428V. i understand that the voltage across both resistors is 7.07V because the multimeter is measuring RMS but how do i calculate the db level.
Thanks for the reply but that still doesn't tell me how to calculate the -22 dB.
You have a voltage divider with impedances:
Z1 = R1 + j*omega*L + 1/(j*omega*C) = R1 + j*(omega*L - 1/(omega*C) )
Z2 = R2
Your measured voltage, call it Vout, is then given by:
Vout = Z2/(Z1 + Z2) = R2/(R1 + R2 + j*(omega*L - 1/(omega*C) ) )
with magnitude:
|Vout| = R2/sqrt( (R1 + R2)^2 + (omega*L - 1/(omega*C) )^2 )
Find peak value by finding roots of the derivative of |Vout| with respect to omega and substitute into Vout, you probably know the drill.
My solution gives:
Peak value = R2/sqrt( (R1+R2)^2 + (L/sqrt(L*C) - sqrt(L*C)/C)^2 ) = 0.0909 V = -20.8279 dBV
for R1 = 10 ohm, R2 = 1 ohm, L = 70 mH, C = 110 uF.
Thanks,
Once you're broke down the equations its made it easier to see what is going on.
Thanks for the help :)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
