Why is the magnetic field inside an ideal solenoid uniform
The magnetic field inside an ideal solenoid is uniform due to the contributions from an infinite number of loops, which balance out the variations in the magnetic field at different points within each loop. Ampere's Law demonstrates this uniformity, as the magnetic field strength, represented by ##|\vec{H}|##, remains constant regardless of the position within the solenoid. The symmetry of the solenoid allows for the assumption that the magnetic field is directed along the coil's axis, with no field present outside. Additionally, the differential form of Ampere's Law confirms that the magnetic field strength remains constant inside the coil where there is no current density. Thus, the uniformity of the magnetic field in an ideal solenoid is a result of its infinite length and symmetrical structure.
jayman16
I understand that the magnetic field at points inside the solenoid is the vector sum of the B field due to each ring. How can the field inside be uniform then since if you consider just one loop in the solenoid the value of the B field is different at different points in that circle or loop.
But a solenoid is not one loop right? Ideally its an infinitely long line of loops. At each point your B field is the sum of the contribution from each of the infinite number of loops.
ya but at different points in each of the loops let it be the center or a point that is off center, the B is different is it not?
Just use Ampere's Law in integral form. Due to symmetry of a very long coil, ##\vec{H}## must be along the coil's axis, and you can assume it's 0 outside.
For the closed line in the integral take a rectangle with one side (length ##l##) along the axis, somewhere well inside the coil and the parallel side outside. Let there be ##\lambda## windings per unit length. Then you have, according to Ampere's Law (I neglect the signs here; you easily find the direction of the field, using the right-hand rule):
$$\int_{\partial A} \mathrm{d} \vec{r} \cdot \vec{H}=\frac{\lambda l}{c} I,$$
where ##I## is the current through the coil. This gives
$$|\vec{H}|=\frac{\lambda}{c},$$
independent of where you locate the rectangle's side within the coil. That's why ##\vec{H}## is uniform.
You can also argue with the differential form of Ampere's Law,
$$\vec{\nabla} \times \vec{H}=\frac{1}{c} \vec{j}.$$
In cylindrical coordinates, with the z axis along the solenoid's axis and with the ansatz due to the symmetry of the problem \vec{H}=\vec{e}_z H(r) you find, using the formulas for the curl in cylindrical coordinates ##\vec{\nabla} \times \vec{H}=-H'(r)##. Since inside the coil there is no current density you get ##H(r)=\text{const}##.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
