How to calculate when an object will be directly
  • Thread starter Thread starter Wheelwalker
To determine when a celestial object will be overhead, one must calculate the local sidereal time (LST) based on the object's right ascension and the observer's longitude. The Greenwich Mean Sidereal Time (GMST) can be found for a specific date, and then adjusted by the observer's longitude to derive LST. Using tools like spreadsheets or online calculators can simplify this process, especially when not near the equinox, as manual calculations can be complex. Resources such as the Astronomical Almanac and various astronomy software can aid in these calculations. Accurate azimuth and altitude require additional calculations involving hour angle, latitude, and declination.
Wheelwalker
I'm having some trouble determining when a celestial object will be overhead (in terms of right ascension, not declination). Since we use solar time, it wouldn't be correct to simply use the right ascension of the object since each day the sidereal and solar time become four minutes different. So, given the celestial coordinates of an object, latitude and longitude of a location on earth, how do I find what time the object will be overhead? I've been grappling with this for awhile now and could really use some help instead of being asked more questions.
Astronomy news on Phys.org
I've actually just made some progress on the problem from my book. I needed to determine the local sidereal time over Cuba at approximately 6 pm in late September. Using the GMT, and assuming (to make it easier) that this event happened on the equinox, I converted Cuba's longitude to hours and subtracted them from the GMT to find the approximate local sidereal time. Is there an easier way to do this? I feel like it would be an absolute pain to calculate LST when not near the equinox.
I wouldn't want to do it in my head, but here's a pretty simple formula to get the sidereal time at Greenwich for any date and time. From there, you just adjust for your longitude, as you did above.
https://sites.google.com/site/physi...ts/universaltimetolocalsiderealtimeconversion
If you don't understand it, just google the various terms such as "Julian date." You might also consider googling for "practical astronomy" or "ephemeris calculations" to get a more comprehensive tutorial on time conversion.
If you just want the answer without doing the calculation yourself, there are lots of sites that will do it for you, e.g.
http://www.jgiesen.de/astro/astroJS/siderealClock/
Yes you would need time but you would also need position. Azimuth and Altitude must be calculated from the Hour Angle, Latitude and Declination with Altitude to be 90 degrees.
HA = f(gst, time and Longitude minus the Right Ascension)
AZI = f(HA, Latitude, Declination)
ALT = f(HA, Latitude, Declination)
Local sidereal time (which is the same as right ascension) is the Greenwich Mean Sidereal Time plus the longitude.
You can look up the GMST at midnight for a particular date in an Astronomical Almanac, and then add the current Greenwich Mean Time (solar) to get your current GMST.
Or you can do the easy thing and download a spreadsheet that calculates GMST for any time you want at any given longitude just by setting the azimuth to 180. Or, if your real goal is correlate your location and your telescope's az/el, it will calculate the RA/dec of the object you're looking at directly instead of you having to figure it out manually. (You should do all of this manually at least once, just because, but I don't think I know anyone that would want to do this manually all the time.)
http://www.setileague.org/software/spreadsh.htm
This has several useful spreadsheets. You want the ra_dec.xls spreadsheet to get right ascension & declination.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
