How Do You Calculate Instantaneous Velocity at Point 2?
To calculate the instantaneous velocity at point 2, one can analyze the distances between points and the time intervals. The distances between points 1 and 2 (5 cm) and points 2 and 3 (9 cm) suggest variable acceleration, as the object speeds up. The average velocity can be determined by calculating the velocities for each segment and averaging them, but it's essential to consider that the acceleration is changing. The position function x(t) = x_0 + v_0t + 1/2 * at^2 can be used to find the average acceleration and subsequently the instantaneous velocity at the midpoint between the two time intervals. Understanding these principles will help accurately determine the instantaneous velocity at point 2.
deficiency4math
Hi,
I was wondering how to solve the instantaneous velocity for this.
I have 3 points which have 5 cm between point 1 and point 2 and 9 cm between point 2 and point 3 (this is easy, i just need to grasp the concept)
The question is "What is the instantaneous velocity for point 2?
How would I figure this out?
thanks :smile:
Do you have any times?
oh, yes, sorry,
the time intervals between the points are 1/40th of a second (lets say)
(sorry, I forgot to post them... I kinda forgot!)
Can you give a little background? What kind of motion is going on here, constant acceleration?
it would be variable acceleration, because the consecutive distance between 1&2 is 5 and 2&3 9... so let's say that each time, the velocity increases by one.
Would I just take the velocity of 1-2 (5cm per 1/40th of a second) and 2-3 (9cm per 1/40th of a second) and find the average of them to get the instantaneous?
Define acceleration in terms of velocity. Does acceleration have to change for velocity to change?
I don't know how accurate you need to be, but what I would do is try to figure out the average acceleration. The object is speeding up, so its position function is:
We traveled x(t) = 14cm in t=0.05sec. Can you find the acceleration? Can you find the velocity at t=0.025 with this?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
