DC biasing using voltage divider
A voltage divider cannot change the mean value of a signal, only its amplitude, making it unsuitable for biasing a signal from -5V to 5V to a range of 0 to 2.5V. To achieve the desired output, an op-amp or a capacitive coupling with a bias network is recommended. One suggested method involves creating a three-resistor network with specific resistor values to manipulate the input signal. By adjusting the voltages on the top and bottom of the divider, it's possible to derive the necessary output through simultaneous equations. Real-world applications must also consider source and input impedance for accurate results.
david90
how do I use a voltage divider to biasing a signal that goes from -5v to 5v so that it goes from 0 to 2.5?
It's not possible. A voltage-divider can only change a signal's amplitude, but cannot change its mean value.
You're hoping to put a signal of 0V (the midpoint of -5 to 5V) and get out a signal of 1.25V. That'd be quite a feat for nothing but a couple of resistors.
You'll need to use an op-amp, or at least capacitively-couple your input to a bias network (perhaps made out of a voltage divider).
- Warren
- Warren
No, I think it can be done in this case. But since this sounds like a homework problem, I'll start by only giving a couple of hints to David.
Make a 3-resistor network with two resistors in series from 10V to -10V. Couple your input voltage into the middle of these two resistors using another resistor. Make the top resistor 10K, the bottom resistor 20K, and the input resistor 10K. Now vary the input voltage between -5V and 5V, and calculate what happens at the output (the intersection of the 3 resistors). Do you see a way to get the voltage offset and scaling that is asked for in the problem? Keep in mind that you can set different voltages on the top and bottom of the voltage divider if that helps. Just write some simultaneous equations...
BTW, in a real world application, you would need to consider the source impedance and the input impedance of whatever circuit came next after the voltage biasing network. In the case of this homework problem, you can probably assume that the output impedance of the source voltage is negligibly low, and the input impedance of whatever is using the output voltage is very high.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
