Can gas giants like Jupiter become stars and create a binary solar system?
  • Thread starter Thread starter wizgrav
    Magnetosphere
Jupiter's magnetosphere extends to Saturn, raising questions about potential interactions between their magnetospheres due to increased solar output. The recent conjunction of Jupiter and Saturn has sparked speculation about its possible effects on Earth, including earthquakes, although gravitational influences would be minimal. The red spot on Jupiter is believed to be largely independent of solar activity, existing even during quiet solar periods. There is no evidence that gas giants like Jupiter can ignite or fuse into stars, as significant mass would be required for such a transformation. Overall, while intriguing connections exist between Jupiter, Saturn, and solar activity, the likelihood of Jupiter becoming a star or affecting Earth through gravitational interactions remains low.
wizgrav
Hi, I don't have a solid background in astrophysics. I need some help.
Jupiter's magnetosphere is elongated by the Sun.
It almost reaches the orbit of Saturn.
What would happen if, by increased solar output, the magnetospheres touched?
Recently we had a conjunction of Jupiter and Saturn. Could that cause the earthquakes?
How does the red eye on Jupiter connect with Sun ?
Is it affected by the sun and jupiter, (Was there a reaction when sun peaked of 2001)?
Could the solar fields contain a reaction on a gas giants surface and "ignite" it?
It would be really nice if you could point me to research.
Thanks in advance.
Astronomy news on Phys.org
See if these help.
Here is a summary of Jupiter's magnetosphere, which apparently goes out as far as Saturn, and that would imply that that the two magnetospheres have touched as Jupiter by-passes Saturn.
http://www.windows.ucar.edu/tour/link=/jupiter/upper_atmosphere.html
http://pds.jpl.nasa.gov/planets/captions/jupiter/magneto.htm
http://www-ssc.igpp.ucla.edu/personnel/russell/papers/jup_mag/
http://www2.ku.edu/~kuspace/outreach/bursts.html
On earth? Using g = GM/r2, one could compare g's for M = mass of moon, Jupiter and Saturn at closest approach to see the relative gravitational effects.
Relation between the Visibility of Jupiter's Red Spot and Solar Activity
http://www.nature.com/nature/journal/v222/n5188/abs/222069a0.html
If one means fusion reactions, the answer is no. There are interactions between atmospheres of the planets and the solar wind, and no ignition takes places.
I think the spots on both sun and Jupiter are created by opposing fields.
Maybe all gas giants and stars are positive "poles" and black holes the negative.
http://www.physorg.com/news119109042.html"
Is it possible for gas giants to fuse? Could that make our solar system binary?
Thanks for caring.
That's an interesting idea, but I believe that the red spot on Jupiter is present even in quiet solar period without sunspots or the massive eruptions. The red spot on Jupiter is certainly a unique feature as planets go.
AFAIK, black holes are far away, so they wouldn't have much influence on us.
V4641 Sgr: The Closest Black Hole Candidate
http://antwrp.gsfc.nasa.gov/apod/ap000117.html
An object many astronomers believe is a black hole has been found only 1500 light-years from Earth, making it the closest black hole candidate.
Thanks for caring.
System 2M1207 is interesting.
For a second star in our system, Jupiter would have to pick significant mass - about 80 times its present mass in hydrogen to become a star.
Here is an interesting discussion on Jupiter and the Galileo spacecraft which crashed into Jupiter - http://www.badastronomy.com/bad/misc/jupiter_galileo.html - it also talks about what would need to happen for Jupiter to become a star.
It is unlikely that Jupiter and Saturn would collide. They are pretty much set in their orbits.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
