Water Flow Rate From A Tap Attached 2 A Tank
To calculate the water flow rate from a 400-liter cylindrical tank with a tap at the bottom, Bernoulli's equation and the continuity equation are essential. The flow velocity can be determined using the formula that incorporates pressure differences, gravitational acceleration, and fluid height. The flow rate is obtained by multiplying the velocity by the cross-sectional area of the outlet. Key variables include the pressures at the top and bottom of the tank, the height of the fluid, and the areas of the tank and outlet. Understanding these components allows for accurate flow rate calculations.
TIPSY
Hi guys. Can u pls hlp me out.
Let's say I have a 400 liter cylindrical tank with a tap at the botom.
how do I calculate the rate at which the water flows from the tap and how far the water mite go?
thanx in advance
thanx in advance
The flow rate at the outlet can be found using Bernoulli's equation along with the continuity equation.
v_2 = \sqrt{{\frac{2}{1- \left( \frac{A_2}{A_1}\right)^2}} \cdot \left(\frac{P_1 - P_2}{\rho} + g \cdot h \right)
CS
EDIT: I forgot to mention that you need to multiply v2 by the cross-sectional area to get the flow rate (v2 is just the velocity).
OK. I think I know what g and h are (gravity and height) but the rest I am clueless so ifyou could just explain further it would be appreciated.
thanks stewartcs.
thanks stewartcs.
P1 is the pressure at the top of the tank.
P2 is the pressure at the bottom of the tank.
If the tank is open to atmosphere and discharges to atmosphere the equation will obviously reduce. If not, use P1 and P2 as applicable.
h is the height from the top of the fluid in the tank to the centerline of the orifice.
A1 is the area of the tank.
A2 is the area of the orifice (outlet).
g is gravitational acceleration.
\rho is the fluid's density.
CS
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
