Law of conservation of linear momentum and energy
The discussion focuses on verifying the conservation of linear momentum and energy during a collision between two bodies of mass 2M and M. The initial kinetic energy (KE) is calculated as MV², and after the collision, the KE remains MV², indicating no energy loss. Momentum before the collision is 2MV, and after the collision, it also totals 2MV, confirming momentum conservation. The absence of potential energy in this scenario reinforces that mechanical energy is conserved. Overall, both conservation laws are upheld in this collision analysis.
Radwa Kamal
A body of 2M(KG) mass at velocity V collided with a body of mass M(KG) at rest.
The first body after collision has a velocity ao 1/3V , and the second moves at 4/3V.
Verify both laws of conservation of linear momentum and energy with explanation.
m1v1f + m2v2f= m1v1i+ m2v2i
KE = (1/2)mv^2
PE=mgh
KE = (1/2)mv^2
KE before collision = 1/2 *2MV^2+ 1/2* M(0)=MV^2
KE after collision =1/2*2M(1/3V)^2+1/2*m(4/3V)^2=1/9MV62+8/9MV^2=MV^2
KE before collision=KE after collision
there is no height then there is no potential energy
(KE+PE) before collision + (KE+PE) after collision
then mechanical energy is constant at any point
KE = (1/2)mv^2
PE=mgh
KE = (1/2)mv^2
Welcome to PF.
I will presume that you figured the momentum was conserved. But that said it should be enough to suggest that since the kinetic energy before equals the kinetic after that no energy was lost to other sources, like potential, or friction, or maybe even sound.
I found it :)
momentum before collision=2mv+zero=2mv
momentum after collision=2m(1/3v)+m(4/3v)=2/3mv+4/3mv=6/3mv=2mv
then Momentum before collision =Momentum after collision
