matt72lsu
- 94
- 0
Four point charges are located at the corners of a square with sides of length a. Two of the charges are + q, and two are - q.
1)Find the direction of the net electric force exerted on a charge + Q, located at the center of the square, for the following arrangement of charge: the charges alternate in sign \left( { + q, - q, + q, - q} \right) as you go around the square.
2)Find the magnitude of the net electric force exerted on a charge + Q, located at the center of the square, for the following arrangement of charge: the charges alternate in sign \left( { + q, - q, + q, - q} \right) as you go around the square.
3)Find the magnitude of the net electric force exerted on a charge + Q, located at the center of the square, for the following arrangement of charge: the two positive charges are on the top corners, and the two negative charges are on the bottom corners.
Express your answer in terms of the variables q, Q, a, and appropriate constants.
4) Find the direction of the net electric force exerted on a charge + Q, located at the center of the square, for the following arrangement of charge: the two positive charges are on the top corners, and the two negative charges are on the bottom corners.
F = k (qQ/r^2) ?
For question 1 I think it is magnitude = 0 because of the pull directions (b/c the signs alternate). For 4, I think the pull will be downward b/c the Q+ will be attracted to the neg charges. For 2 and 3 I'm not exactly sure what they are asking, so can somebody help me with my comprehension of what they are asking? Thanks!
