Conservation of Energy and Inertia resist acceleration
The discussion revolves around an experiment to demonstrate the conservation of energy and the effect of inertia on acceleration using rolling objects down a ramp. The experiment shows that increasing the ramp's height affects potential energy and final velocity, while changing the slope's steepness keeps final velocity constant, supporting the conservation of energy principle. The participant is confused about calculating final velocity, considering both translational and rotational kinetic energy, and seeks clarification on the acceleration of rolling objects. It is noted that rolling objects have different accelerations compared to sliding ones, and the acceleration formula involves the moment of inertia, which varies by shape. The conversation emphasizes the need to accurately account for both forms of kinetic energy and the specific shape of the objects to derive correct acceleration values.
zenite
Hi Guys, I am doing an experiment to prove
1) Conservation of Energy
2) Inertia resist acceleration
The experiment is simple, rolling objects down a ramp.
So I timed the time taken for each object to reach the finishing line from rest.
To prove conservation of energy, I increased the height of the ramp, and then the steepness of the slope (height remains the same).
So when the slope steepness changes, the final velocity (hence kinetic energy) remains the same for an object. When height changes (steepness remains constant), the final velocity changes (potential energy changes, hence final kinetic). Is this reasonable to conclude that conservation of energy is true? The object is assumed to be pure rolling, hence no frictional effects.
And then for inertia. I used different shapes, solid sphere, hollow sphere and hollow cylinder. I got different timing for the shapes. The larger the inertia the longer the time taken. So how do I go about explaining inertia resist acceleration?
1 thing that confused me here is that how can I calculate the final velocity of the object with the data I had. I have height, degree of slope, displacement, mass. How do I get the final velocity? Can anyone help here?
My approach:
I used conservation of energy equation, PE1 = KE2 to find my final velocity. But can I really use it if I am trying to prove the theory is true? I then tried using kinematics to solve. But then I have to assume acceleration is constant. Is it constant? and what is the acceleration? Because inertia resist acceleration, each object have a different acceleration, correct? I thought a=g sin(theta) initially, but I am sure that's wrong.
There is a problem.
You said that you are rolling objects down a ramp. The initial PE that you had at a particular height is being converted NOT just into the KE of the object via the translational motion, but also in the ROTATIONAL kinetic energy. So the energy is being converted into two different forms, not just into translational KE. To get the full conservation, you have to account for both.
Zz.
Yes, I do account for both. Will it affect the theory in any way?
The formula I used to calculate final velocity:
mgh = 0.5mv2 + 0.5Kmv2 where k is a constant dependable on shape of object (inertia)
so v = sqrt (2gh/(k+1))
Then I need to compare the theoretical velocity (the one above) with the practical one. problem is, how do I solve for final velocity? I have displacement and time. Is that sufficient? Can I can assume acceleration is constant, and if so what is the acceleration? Pls advice.
Where did you get that? You need to look up the expression for rotational KE. The fact that you are using the same "v" for both makes it incorrect.
Zz.
Sorry, I skipped some steps. Here is the full working, pls let me know if its wrong.
mgh = 0.5mv2 + 0.5Iw2
For pure rolling, v = rw
mgh = 0.5mv2 + 0.5(kmr2)(v/r)2 = 0.5mv2 + 0.5kmv2
The inertia formula is used as kmr2, if its a sphere, k=1.
For the acceleration down a ramp for a rolling object, I did some research and found this:
Rolling objects have lower translational acceleration than that of a sliding, hence a is not equals to g*sin(theta). From a website, it states that a = sin(theta)*g*5/7
Can anyone tell me where does the 5/7 comes from? It seems like it comes from the moment of inertia, so the formula only applies to a certain shape. How do I derive the acceleration? Is the acceleration of a rolling ball even constant in the first place? I would really appreciate it if someone clears my doubt on the last question.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
