COnstant acceleration - stone in a well
A stone is dropped into a well, and the splash is heard 3.5 seconds later. The total time includes both the time for the stone to reach the bottom and the time for the sound to travel back up. The calculations involve using the equations of motion for the stone and the speed of sound to relate the two times. The depth of the well can be determined by setting up equations for both the stone's descent and the sound's ascent. The discussion confirms that the approach to solve for the unknowns is correct, leading to the depth of the well being approximately 55 meters.
mstud
You drop a stone down into a well to find the depth of the well. You hear the sound of the splash 3.5 s after you let the stone go.
s(displacement)=v_0t \cdot \frac 12 at^2
I have
t_{total}=3.5 s
Stone: v_0=0, and a=9.81 m/s^2.
Sound: v=340 m/s, a=0.
If the sound had not used a small part of the total time, the answer would have been:
s(displacement)=v_0t \cdot \frac 12 at^2=0*3.5 s + \frac 12 * 9.81 m/s^2*(3.5s)^2=60 m
But the answer key of my book says 55 m. I see why, but I don't know how I can get that answer... Please help, anybody out there!
basically in this question there is 3 unknowns and 3 constraints
3 unknowns
- time for rock to reach bottom of well
- time for sound to travel out of the well
- depth of well
3 constrants
- time takes to reach the bottom of the well and depth of the well is related to the equation you used
- time taken for sound to travel out of the well follows a simple s = vt relationship
- total time is 3.5s
can you see how to solve this now?
Hmmm, not quite sure. Depth of well, s, is the same both when the stone and the sound travels it.
Sound: s(displacement)= vt = 340m/s *t_{sound}
Stone:
s(displacement)=v_0t\cdot \frac 12 at^2=0∗(3.5s-t_{sound}) +\frac 12 ∗ 9.81m/s^2 ∗ (3.5s-t_{sound})^2=0+12∗9.81m/s^2∗(3.5s-t_{sound})^2=12∗9.81m/s^2∗(3.5s-t_{sound})^2.
I can relate these two equations to each other: 340m/s *t_{sound}=12∗9.81m/s^2∗(3.5s-t_{sound})^2 and solve this equation for t_{sound}. Am I on the right track now?
looks like you are :)
That was right :)
Thanks a lot !
glad to help :biggrin:
