Why Does RMS Velocity Increase During Adiabatic Compression?
The discussion focuses on the relationship between adiabatic compression and the increase in root mean square (rms) velocity of a gas. Adiabatic compression occurs without heat transfer, leading to a rise in temperature, which in turn affects the gas's kinetic energy. The equations provided illustrate how temperature and volume changes during compression relate to rms velocity. As the gas is compressed, its volume decreases, resulting in an increase in temperature and consequently, an increase in rms velocity. Understanding these principles is crucial for grasping the thermodynamic behavior of gases under adiabatic conditions.
UCstudent
rms velocity and compression. Please help!
Explain why the rms velocity of a gas increases when it is adiabatically compressed.
None
I know that compressing a gas decreases the volume, but I don't know details on how it would effect rms velocity
Do you understand what adiabatically compressed means? If you don't, google it :-)
If you compress a gas adiabatically, no heat is transferred from the gas to its surroundings. You know that compressing a gas increases the temperature (and you can calculate by how much using your adiabatic relations).
T*V^{γ-1} = constant
T_{0}*V_0^{γ-1} = T_1*(V_0 + ΔV)^{γ-1}
Thus
T_1 = T_{0}*(V_0/(V_0 + ΔV))^{γ-1}
And
ΔT = T_1 - T_0
Then
ΔE = (3/2)N k_b ΔT= (1/2)N m (Δv)^2
Or
Δv = \sqrt{(3/2) (k_b ΔT)/m}
And I was going to make you figure it out yourself. :-(:wink:
