Would a Falling Hot Coal Still Burn Someone on the Ground?
The discussion centers on whether hot coals thrown from a rooftop would still burn someone on the ground. The poster proposes a mathematical model using heat transfer principles, considering factors like thermal diffusivity and the temperature of the air. Concerns are raised about the assumptions made, particularly regarding the steady state of air flow and the complexities of heat transfer between materials. The possibility of the coal still undergoing combustion during its fall is also explored, suggesting it could be hotter upon impact. Overall, the inquiry seeks to refine the model for different coal shapes and conditions.
Xian
So a sadistic friend of mine posed this question:
If we were to have a bbq on the roof of this building, and threw the coals off of the roof, would it still be hot enough to burn someone at the bottom?
Of course this question can be thought of in two ways: a) would the surface still be hot enough at the bottom or b) would the interior be hot enough at the bottom (since the coals would probably break, its a relevant question).
At the time I couldn't figure out how to model the problem, but now here's my approach:
Model the coal C as some compact 3-dimensional subset of R^{3}. Assume that the wind relative to the ground is negligible, that the air temperature is consant, and that the initial interior temperature of the coal is uniform. Let h be the height of the building, let \alpha be the thermal diffusivity of the coal, let T_{air} be the temperature of the air, and let T_{0} be the initial temperature of the coal.
Here's a big assumption, since the air in contact with the coal will be replaced by fresh air at temperature T_{air} as the coal falls, we will model the temperature of the falling coal by the heat equation with steady state boundary conditions. More specifically we will have T(x,y,z,0)=T_{0} in C and T(x,y,z,t)=T_{air} on the boundary \partial C and let the temperature evolve for a duration of \sqrt{2h/g} (the fall time) under the heat equation, \frac{\partial T}{\partial t}-\alpha\nabla^2 T = 0.
Is this a good model? I can already see where a few problem would arise. First of all, I'm concerned that the mathematics of heat transfer between two materials is more subtle than I assumed. Moreover, I'm worried that my assumption that air rushing past the coal can be treated as a steady state boundary condition is also wrong. If anything though, I think that final temperature distribution for the coal under this model would underestimate the real life solution at all points (is this fair?). I look forward for any comments, and eventually look to try to solve this for specially shaped coals (cubes, spheres, etc).
If the hot coal is still undergoing combustion when it is thrown off the roof it may actually be hotter when it reaches the ground. Moving through the air it will continually be leaving behind CO2 and moving into air with more O2, somewhat like blowing on an ember makes it heat up.
Interesting, I didn't consider that. How can one tell if the coal is still undergoing combustion? And let's assume that its no longer combusting. In that case, how's the model look?
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
