Why Is the Potential Infinite at the End of a Charged Rod?
  • Thread starter Thread starter schaefera
    Potential Rod
The discussion centers on the calculation of electric potential at the edge of a charged insulating rod, where it is noted that the potential approaches infinity due to the mathematical properties of the natural logarithm. This raises concerns about the physical implications of such a result, particularly when considering additional charges placed on the rod. Participants highlight that a uniform charge distribution on a one-dimensional object leads to infinite potential, suggesting that a more realistic model should involve higher dimensions. The conversation emphasizes the need for a better understanding of potential in relation to the geometry of charged objects. Ultimately, the discussion reveals the complexities and limitations of modeling electric potential in simplistic terms.
schaefera
Hi all!
So I've been doing some work with potential calculations, and I seem to be running into a bit of trouble with figuring out how to think about the potential due to a rod at the very edge of it.
Imagine an insulating rod with charge Q is placed along the positive x-axis, with its left end at the origin. I can calculate the potential anywhere on the y-axis, and anywhere on the negative x-axis quite easily. But when I try to take the limiting case of a point at the left end of the rod, something strange happens: I can let y approach 0, or x approach 0 in either of the expressions, and I find that the potential at the end of the rod is infinite. This is because the potential contains the natural log.
I contend that this doesn't make physical sense! You see, what if I had instead charged the rod to a charge Q+q. If the potential when charge Q is already on the rod is infinite at the end, how can I place the extra bit q on the rod? But I know that Q can have any value, which means I should be able to make Q large enough that it includes that extra bit, had I wanted to from the start.
I don't understand. Why are you trying to find the potential between 2 points on the rod if the rod is charged with Q? Wouldn't there be 0 potential?
I think not- for one, it's not a conductor, and for two this is relative to a 0 potential at infinity, the way that I'm thinking about it (I'm integrating dV over the entire rod to get V, but this all presupposes that V=0 at infinite distances).
Do you have a charge on the end of the rod, or is the whole rod charged?
The defiance of physical sense reflects the unreality of the model. A uniform charge over a one-dimensional manifold will always produce infinite potential on the manifold itself.
To avoid this you need to make it at least 2 dimensional, but might as well make it 3. 5.8.7 in http://www.astro.uvic.ca/~tatum/celmechs/celm5.pdf derives the (gravitational) potential due to a uniform solid cylinder.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
