Why Do Rocket Hobbyists Use Non-Stoichiometric Mixes in Propellants?
  • Thread starter Thread starter adoado
The discussion centers on the use of potassium nitrate and sorbitol as propellants in rocket motors, raising questions about the use of non-stoichiometric quantities of reagents. Non-stoichiometric amounts can lead to leftover reactants and potentially enhance reaction completeness. It is clarified that standard combustion typically requires gaseous oxygen, while iron oxide may serve a different role, possibly as a catalyst rather than an oxygen source. The effectiveness of iron oxide in the reaction is questioned, suggesting that it may not provide sufficient oxygen without complex reactions. Understanding these chemical interactions is crucial for optimizing rocket propellant performance.
adoado
The combination of potassium nitrate and sorbitol and commonly used by hobbyists as a propellant for rocket motors.
The combustion equation is given below:
I have a few very simple questions based on the chemistry of such a reaction.
Firstly, many people do not use stoichiometric quantities of each reagent. Why is this? I thought the idea was to get the 'exact' amounts as to optimize the reaction? Or is this simply optimizing the efficiency of the utilization of the reagents into products?
Secondly, there is an oxygen term there; does this need to be available as a gas? For example, a lot of people seem to add Iron Oxide to this mix, probably to give this oxygen component. My question is, why iron oxide - can anything with an oxygen work?
Thanks for reading,
Adrian
Chemistry news on Phys.org
Thanks for reading,
Adrian
Non stoichiometric amounts just means some of the reactants will be left over. This could also shift the equilibrium and get a more complete reaction with respect to other reactants.
Yes, standard combustion uses gaseous oxygen. I'm not sure about the iron oxide chemistry. It may act as a catalyst, or alter the actual reaction mechanism.
I doubt iron oxide is the oxygen source, because that would require a large amount, and require some sort of splitting reaction.
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
