How Does Heat Transfer in an Electric Oven Work?
Heat transfer in an electric oven occurs primarily through conduction, convection, and radiation, with the heating coil initially at a higher temperature than the air. As the air temperature rises, the surface temperature of the heating coil also increases but does not necessarily remain constant at 500F. The maximum temperature an oven can reach is influenced by both the heating coil's capacity and the insulation of the oven's exterior. If the oven is perfectly insulated, the heating coil could theoretically raise the air temperature significantly, but practical limits exist to prevent overheating or melting. Ultimately, the relationship between the coil's surface temperature and the air temperature is not directly proportional, as various factors affect the heating dynamics.
zzinfinity
I'm curious how heat transfers between the heating element in my electric oven and the air in the oven. Say when I first turn on my oven the air is at room temperature (say 70F) and the surface temperature of the heating coil is at say 500F. After some time passes, the air in the oven rises to 350F. Does the surface of the heating coil remain at 500F or does it change with the ambient conditions?
And a related question. Is the maximum temperature an oven can reach determined by the heating coil, or the insulation of the exterior. Suppose I was able to insulate my oven so well that no heat could escape to the outside air (hypothetically) . Would the heating coil continue to raise the air temperature until it melted? Or would something else limit the heating.
Any thoughts would be appreciated! Thanks!
Conduction, convection and radiation -- though the radiation is mostly between the coil and the sides of the oven (and whatever you are cooking), which then turns to convection and conduction as well.
The heating coil will heat up as the air in the oven and the surfaces of the oven heat up.
Its both/either. You can raise the temperature capability by adding insulation or adding more heat.
Thanks for your response! Do you have an idea by how much the coil surface temperature rises? If the air temperature increases by 300 F does the surface temperature of the coil also increase by 300 F or is it a different proportion?
When you say you can raise the temperature by adding more heat, what exactly do you mean by that? Bigger coil, bigger current? And if I insulate my over perfectly such that no heat escapes, is the temperature the coil can bring the air to bounded?
Thanks!
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
