Water's role in biological catalysis?
  • Thread starter Thread starter hivesaeed4
    Biological
Water is essential for biological processes involving catalysis primarily because all biological systems evolved in aqueous environments, making water a fundamental solvent for these reactions. While some processes can occur in different solvents, they tend to be significantly slower due to water's unique properties. Enzymes, which are the main biological catalysts, are complex polymers that require specific folding to function effectively. The folding process is largely driven by the hydrophobic effect, where non-polar regions of the enzyme move inward, and polar regions remain outward. In non-aqueous solutions, enzymes cannot achieve the correct conformation, rendering them ineffective in catalyzing reactions.
hivesaeed4
Why is water required to be present in biological processes involving catalysis. I read that online and the way it was written made it look sort of obvious ( like, duh ) but I don't understand it. Help?
Chemistry news on Phys.org
All biological processes evolved in water solutions, so the presence of water is taken as granted. Doesn't mean some of them can't be replicated in different solvents, but I suppose they will be much slower, as water has very particular properties.
Biological catalysts (for the most part, enzymes) are complex polymers that must fold into a specific shape in order to perform their function. Much of the energy driving the folding of these polymers into the correct shape comes from the hydrophobic effect, which forces non-polar regions of the polymer toward the interior of the structure and polar regions toward the exterior. In non-aqueous solutions, these polymers will not fold correctly and therefore will not be able to catalyze any reactions.
Thanks guys.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
