Power output of a simple generator
To convert the RPMs of a turbine, such as a windmill, into power output, the relationship is defined by the equation: Power = RPM x Torque / 5252. The mechanical power output depends on factors like wind speed and turbine design, with the maximum theoretical power given by Power_max = 0.5 x Swept Area x Air Density x Wind Velocity^3. Efficiency in converting mechanical to electrical power is typically over 90%. Understanding these principles is crucial for determining if a windmill can power specific appliances like a refrigerator.
treplag
How do I convert the RPMs of a simple turbine (e. g. a windmill) into the power it generates? Let's say that I want to know if a single windmill of a certain size can power a refrigerator. Assume that I already know how long the blades have to be to produce the RPMs, and I know the energy requirements of the refrigerator. I am only looking for a basic equation of RPMs to power (watts or joules). Thank you.
I don't know the answer, but I at least know that its not that simple.
RPM alone don't tell the full story. You could get a small baby-toy scale turbine to rotate at the same RPM as a big power turbine.
What you can get is - for a given wind speed, and for a given turbine type of certain size you can find out the mechanical power output. The mechanical to electrical conversion is often >90% efficient.
The theoretical limit to the maximum power that can be harnessed is given by
Power_max = 0.5 x Swept Area x Air Density x Win_Velocity^3
But to get anywhere near the maximum power you need to have a state-of-the art turbine design.
Hi, I_am_learning - Thanks for your input. I was afraid it might not be as simple as I had hoped. Apparently I will have to keep digging.
Thanks, Russ!
russ_watters said:
Power is rpm times torque divided by 5252 (English units). http://www.largiader.com/articles/torque.html
Thanks Russ !
i've been looking for an easy to remember number for that conversion, and 5252 is it .
52 twice makes me think of Tex Ritter's "Deck of Cards"
So at 5252 RPM torque and horsepower have the same number. That's right in operating band of small outboard motors i tinker with.
old jim
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
