Finding the Best Solar Pump and Panel for 1 HP Pump
  • Thread starter Thread starter jack001
    Pump Solar
To power a 1 HP solar pump, approximately 2000 watts of steady power and triple that for starting surge is required, translating to around 60 square meters of solar cells. The cost of solar cells is estimated at about $1 per watt, leading to an installation cost of around $10,000 or more. Solar cell efficiency is typically around 10% for commercially available products, despite higher efficiencies being achieved in laboratory settings. Smaller solar pump systems can operate effectively with less power, but they differ significantly from the 1 HP setup discussed. Alternative methods for solar pumping, such as solar concentrators, may be explored, but the feasibility and efficiency need further investigation.
jack001
hello PFs,
I am working on solar pump but unfortunately i am new to this. Confused which solar panel is best to buy for 1 HP pump. And even what type of pump to use. Want to make it as efficient and cheap as possible.
Thanks.
A 1HP pump is pretty substantial.
You would need about 2000 watts steady state and about triple that for the starting surge. Noonday solar power is about 1000 watts/square meter and cell efficiency is about 10%, so you would need 60 square meters of solar cells, almost a solar field, to power your pump.
Afaik, the cost of solar cells is about a dollar a watt, maybe twice that installed.
So your installation pencils out around $10,000+/-. Is that cheap enough to be worth it?
thank you for your interest in the matter etudiant,
I am from India and i guess noonday solar power will be more..
One more thing i am confused, u said the cell efficiency is 10% only, what does that mean? I heard solar cell is most efficient way of converting into electricity.
and how do this people pumps water via using such a small solar cell?
http://www.solarpumps.com/files/QuickSiteImages/redcows_and_unit_pic_cropped.jpg
sorry if i am wrong anywhere coz i am new to this solar pumping thing.
The 1000 watt/sq m is with the sun directly overhead, even in India.
The solar cell efficiency has been boosted to well over 50% in the lab, but commercially available product is nowhere near that. The 10% assumed is a good place to start from, it may be a bit more, but not enough to matter.
The solar pump setups you show are much smaller than the 1hp design the OP requested.
do you know any other way of pumping through solar without using solar cell? will solar concentrator work?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
