Designing a Discus Rotator: Motor Solutions
  • Thread starter Thread starter dt1156
    Designing Motor
The discussion focuses on designing a device to rotate a 2kg discus for data collection purposes, specifically to measure acceleration using a microcontroller. Key considerations include the discus's specifications, such as its 9-inch diameter and the desired rotational speed, estimated at around 10 revolutions per second. Participants suggest using a ceiling fan motor or an old vinyl record turntable for the rotation, emphasizing the need for careful speed control due to the discus's low resistance. The design aims to gather data without the need for actual throws, ensuring safety and accuracy in measurements. Overall, the thread highlights the importance of selecting an appropriate motor and understanding the mechanics involved in the project.
dt1156
Hey guys looking to design something that will rotate a 2kg discus in place. I attached a simple schematic of what it will look like. I also don't know what kind of motor to use to rotate the shaft. I went to Fry's but their motors looked to weak to power it. Anyone know a site I can buy a motor that can get the job done for me?
Hi dt1156! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
One major omission in your specifications: the speed range over which you wish to spin it. Also, would be worth pointing out your discus's diameter.
Are you planning mains operation, or a low voltage? My first thought is a ceiling fan motor and speed controller, but take great care, because a smooth discus is going to offer far less resistance than a big fan, so the discus will have a much faster top speed. This could be dangerous.
To what purpose will you put this spinning disc?
A fan is a good idea. My first thought was to hit a surplus store or scrapyard and grab an old vinyl record turntable. You already have 2 or maybe 3 mechanically selectable speeds, with the option of adding an electronic controller. It has the advantage of needing only a restraint such as a couple of straps or some Velcro as opposed to an entire mounting system.
The discus's diameter is 9in, 5/16" screw size and weights 2kg and round shape. I've included a picture of a discus that looks very similar to mine. The point of this design is to create a test to gather data from the discus while it is in rotation without having anyone actually throw it. This is a group project where my group will be placing an acceleramator inside the discus and a programming a microcontroller to convert the acceleration readings into the distance the discus traveled. I'm just designing this rotational test part.
... One major omission in your specifications: the speed range over which you wish to spin it. http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon6.gif
Not much faster than the average rotational speed of a discus thrown by a olympic athelte. I couldn't find any measurements of a discus thrown by olympians so I asked my group and someone took a guess at around 10 revolutions per sec which is around 62 rad/s.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
