Force in field? Why isn't it constant?
Distance significantly impacts the strength of gravitational, electric, and magnetic fields, with force decreasing as distance increases, typically following an inverse square law. This variation in force is essential for the stability of physical systems, as a constant force would disrupt fundamental interactions. While some fields can exhibit uniform strength under specific conditions, most do not, and their behavior is dictated by governing equations derived from experimental data. The diminishing force at large distances approaches zero but is never truly zero. Understanding these principles is crucial for grasping the nature of fields and their effects on matter.
Wiz700
Distance is a key variable with fields, however, why is it, in any field(Gravitational,Electric,Magnetic) as "d" increase, F decrease substantially?
Why can't the force x, be constant all around the field. Amazingly, the force is different at each value of d, well in most cases its zero when d is a large number.
Because its not. Why would you want it to be that way, anyway? The falling off of the strength of the field as the square of the distance is literally what makes the world go round. Atoms wouldn't exist, tissue wouldn't exist, WE wouldn't exist. (I'm starting to sound like a discovery show commentator now :-p). Try building a computer simulation of your suggested universe and see how things turn out once you hit "run." Then you'll know why the 1/r^2 law is fine just the way it is.
Well, technically, it is never zero, but it does get vanishingly small pretty fast.
You are thinking of specific field configurations (the Newtonian field, Coulomb field, and magnetic field due to a current wire respectively). The electric field due to an infinite charged plane is uniform, the gravitational field within the Earth is approximately uniform, the magnetic field within an infinitely long current solenoid is uniform etc.
Well...DiracPool and WannabeNewton mentioned good points...but I think I still can add sth.
As the last post says,not all fields have the same spatial behavior...and for everyone of them,you can ask why it is like this...and for all of them,there is only one answer:because of the equations governing the fields! And more or less,those equations are determined by experimental data and more fundamental theories.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
