Ergun Equation reulting to zero pressure ratio
In the discussion, a user is attempting to model a packed bed reactor using the Ergun equation but encounters a problem where the pressure midway through the packed column drops to zero, leading to a failure in their numerical method. They express concern about whether this zero pressure indicates that gas flow will cease, potentially signaling a physical phenomenon such as the destruction of the packing material. As they experiment with increasing the volumetric flow rate (Vo), they observe that the pressure decreases significantly, approaching zero at high flow rates. This prompts questions about the implications of a zero pressure ratio (P/Po) in their calculations. Other participants clarify that increasing flow rates naturally lead to greater pressure drops in the packed bed, and the user ultimately realizes that they were looking for the concept of fluidization velocity, which relates to the conditions under which the bed may no longer support gas flow.
maistral
I was trying to emulate a packed bed reactor, and apparently the pressure midway at the packed column became zero, until my numerical method failed altogether (as the pressure variable in the Ergun is at the denominator).
I'd like to be enlightened about one thing - does this phenomena (zero pressure midway the packed column) has something to tell me at what will happen at the end? No gas flow or something, perhaps? Thanks.
EDIT: Sorry for the title spelling error, it's 'resulting', not reulting.
The pressure should not go to zero if you are using the ergun equation. Please write your form of the ergun equation so we can see what you are dealing with.
Chet
I was toying around the flowrate, Vo. When I assign increasing values for Vo, I found out that the pressure is going down.
What determines the pressure at the inlet and outlet of the bed?
I'm really sorry, I didn't understand the question :|
Actually what's happening is that, the inlet pressure is at 7.5MPa, and I am using the Ergun equation to find out the outlet pressure. What's happening is that if I toy around the Vo by increasing it (volumetric rate), the pressure decreases rapidly until it approaches a certain high Vo value and the pressure approaches 0.
I was wondering if this is equivalent to a physical phenomenon when the exit pressure becomes zero (ie. the gas won't flow anymore, the packings get destroyed, or something).
What you are saying is that, as you increase the throughput rate through a packed bed, the pressure drop through the bed increases. Why does this surprise you?
Uh, I do know that the pressure should go down, but what I mean is that the pressure ratio at the end given a certain high flowrate is zero; does this signify something as a physical phenomenon? No effluent or something?
This is my first time to see a zero pressure ratio in my calculations, I'm sorry. XD
I don't know what you mean by the pressure ratio.
Chet
I mean P/Po is going towards zero. The P there at the denominator is continually decreasing, causing the entire thing to approach zero apparently.
I was wondering what does this have to do as a physical phenomenon, when the exit pressure is zero.
Arr, nevermind. Fluidization velocity is what I was looking for, apparently. Thanks.
