Why does loose tensor tympani cause hypoacusis?
  • Thread starter Thread starter tarekatpf
    Cause Tensor
The discussion centers on the role of the tensor tympani muscle (TTM) in ear function, particularly its protective mechanism against loud noises and its interaction with sound frequencies. A loose TTM can lead to a flaccid tympanic membrane (TM), which theoretically could cause increased sensitivity to sound (hyperacusis) due to the TM vibrating more easily. However, the TTM primarily serves to dampen loud sounds and adjust for low frequencies, suggesting that its flaccidity may not directly result in hearing loss but rather expose the ear to potential damage from loud noises, leading to either hypoacusis or hyperacusis depending on central nervous system involvement. The TTM's protective role is emphasized, with its contraction reducing lower frequency acuity. Despite concerns about a loose TTM leading to high-frequency hearing loss, it appears that the TM quickly regains its tension, mitigating this risk.
tarekatpf
If the tensor tympany is loose, the ear drum is also loose. But then, the ear drum will vibrate even by weak sound waves, which will cause increased vibration of malleus, incus, and stapes. Isn't that supposed to cause hyperacusis instead?
Biology news on Phys.org
The primary purpose of the tensor tympani muscle (TTM) is to damp loud noises and adjust for low frequency sound waves. If it is flaccid, the middle and inner ear is subject to injury. The results of injurious loud noises or acoustic shock (AS) can be either hypoacusis (hearing loss) or hyperacusis. CNS involvement may play a role as to which it is. Clearly, in the absence of protection against loud noises, the tympanic membrane (ear drum or TM) and possibly the middle ear bones and cochlea are subject to injury which can lead to hearing loss.
As far as I know, the TTM does not significantly impinge on hearing directly, but primarily acts in a protective role. By relaxing, it serves to augment lower frequencies in conjunction with the stapedius muscle. However, this apparent effect is due to the fact that contraction of the TTM primarily decreases acuity in the lower frequencies.
http://www.noiseandhealth.org/artic...;issue=63;spage=117;epage=128;aulast=Westcott
EDIT: In theory, a loose TTM would result in a flaccid TM resulting in a high frequency hearing loss at least, but that doesn't seem to happen. The TM quickly regains its proper level of tension.
http://books.google.com/books?id=HS...epage&q=flaccid tensor tympani muscle&f=false
Thank you very much for your answer, and the links. And sorry about the belated reply.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) The structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
